Disable sensors
potc1980
Disable sensors
Is there anyway to dis able the tyre pressure sensors and windscreen wash level sensors?
- x 2008
Re: Disable sensors
TPMS yes, via a Lexia
Screen level....don't know
- x 6950
Re: Disable sensors
Washer fluid level is technically a basic but required warning and isn't configurable much like brake pressure loss or engine overheating.
vborovic
- Locked user account
- x 40
Re: Disable sensors
If it is anything like the X7's electronics, then the washing level sensors goes to the BSM under the hood ... if you would take out just one wire from the related connector, it should fool the car into thinking that the washing liquid is never empty (the sensors reports low level only, closing the circuit) ...
- x 6950
Re: Disable sensors
I didn't want to suggest hammer and tongs approach - just causes headache for next owner (or not)
vborovic
- x 40
Re: Disable sensors
No hammers required, a flat screwdriver to take out a single pin connector ... the hammer approach would be to simply cut the single wire before it reaches the pin connector ...
mikal
Re: Disable sensors
Re sensors. One of my tyres had a metal cap and it sheared off when I removed it and when I came home from the garage who fitted a reg valve I threw the old sensor away.............I know, I know.....so I need a complete new one. Any ideas where I can get a cheap replacement or can I disable the bongs and "service" note on the dash.
2008 C5 saloon 2.0 oil burner
BenC5HDi
- Not Mike
- x 45
Re: Disable sensors
I've had all the valves in my car that has TPMS replaced with standard ones and the TPMS disabled via Lexia.
mikal
Re: Disable sensors
I know nothing.............lexia?
vborovic
- x 40
Re: Disable sensors
Lexia is a diagnostic software that's used to maintain the car ... today you can't do a service on a PSA car without it ... that's standard Dealer/Service equipment
- x 5688
Re: Disable sensors
mikal wrote:I know nothing.............lexia?
Look in this thread for members with Lexias who would be prepared to run a diagnostic for you.
