Xantos and Xantia madness
- x 1982
Re: Xantos and Xantia madness
What do you think about that locking tool Jim ?
- x 8224
Not a lot! The pukka Citroen tools are the only ones to useStickyfinger wrote:What do you think about that locking tool Jim ?
- x 1982
OK.....but why ( just out of curiosity )
- x 8224
On the ES9 I doubt there's room to insert the clamping tool and also because they're verniers, that's not the bit to lock, it's the inner hub that needs locking and that can only be locked with pins..Stickyfinger wrote:OK.....but why ( just out of curiosity )
All you need for the ES9 is five 8mm rods...
- x 1982
Cheers mate......I (Mr thicko) understand now
- x 8224
No worries, the ES9 is actually deceptively easy to do...Stickyfinger wrote:Cheers mate......I (Mr thicko) understand now
Next time I'm down your way I'll bring the timing kit down and do a demo on your spare engine....
xantos
- x 10
Yesterday changed the auxiliary belt and tensioners on TD. Quite pricey these things... It was squeking and the belt was vibrating. Now wouldn't it be nice if the belt snapped and got pulled into the timing belt
Xantia Break 1.9TD (jammed b****!)
Xantia Activa 2.0 TCT + LPG (1998) (peeing b****!) RIP
Xantia Activa 2.0 TCT (1998) (burnt b****!)
Xantia Activa 3.0 V6 (1998) (not a b****! yet
C4 Exclusive 2.0 HDi (gear shifting b****!)
- x 8224
It has happened with quite devastating consequences Xantos so very wise, even though it's not the easiest job in the world...xantos wrote:Now wouldn't it be nice if the belt snapped and got pulled into the timing belt![]()
A loose auxiliary getting tangled up in the cambelt can easily wreck the head...
HansNOR
- x 7
xantos
- x 10
Changed the front pads on TD, the discs are still OK. Just needed to grind the edge of.
@HansNOR: I don't know why the don't show. I use "tinypic" for uploading. Maybe admins can help...
- x 1982
xantos
- x 10
My images are from tinypic (eg. http://oi66.tinypic.com/9kti6b.jpg ), print screen from HansNOR is from imagashack.
- x 1982
Onlinemyglaren
- x 5622
HansNOR
- x 7
all the pics came up today, but obviously not the day I posted the pic
I've had a few reboots in between so that might have helped clear things up.
Now that I can see what is going on I must give props on the V6 Activa
