Dremmel....Homebase
x 5683
Re: Dremmel....Homebase
It is the inlet valve that needs the diaphragm, not the flush siphon.
I have one here but it is too thick for the valve in question. Have bodged it twice previously and it won't bodge again.
Like these.
Plenty of sources around here, just a matter of remembering what I went for when I get there :(
Drove past Scotswood B&Q on my way there and home but too lazy to make the slight detour off the A1.
Should have gone the 695 but the satnev rebelled.
x 8444
Been there with cisterns. I took the easy option and replaced the whole innards. We suffer terribly here with limesacle and most plumbing bits fail because of it..
The only way to keep a kettle going is to have a Brita Filter one...
x 5683
Dreading the day it needs the siphon replacing, or the inlet valve assembly.
It's all enclosed so the plasterboard will all have to come out to get at it.
It's my daughter's and every time I fix something at least one other thing breaks.
isisalar
x 3
Unread post by isisalar »
A piece of rubble sack does very well too, mines lasted about 15yrs now.
J reg 1.9d auto BX first Citroen
M reg 1.9d auto Xantia lx
N reg 1.9 td Xantia VSX Estate
T reg 2.0HDI Xantia Exclusive Estate Present car
M reg 106 diesel red
L reg 106 diesel white
02 Saxo 1.1i desire wife's present car(sadly now very ill cambelt gone- Doh)
x 5683
I have a full siphon assembly kicking around here somewhere.
Bought it for work as one appeared to be broken, turned out there was about 500 fag filters in the flush pipes and chambers.
x 8444
Fags are responsible for some terrible things :(
dnsey
x 19
Unread post by dnsey »
isisalar wrote:A piece of rubble sack does very well too, mines lasted about 15yrs now.
Exactly the same here!
