Hydractive Humming...
DS21
Hi guys,
Happy New Year...!
I noticed this today, and I don't know if it's normally like this or it's an issue but I noticed an electrical humming noise which appears to be coming from the electrovalve which is located just behind the radiator
I started pulling fuses to isolate the power source and when I removed the 20amp Hydractive fuse the noise went away, any idea what could be wrong or please confirm if this is normal?
Thanks folks..
Happy New Year...!
Thanks folks..
- x 1457
Re: Hydractive Humming...
Assuming that this is a Xantia, then it is normal for the hydractive electrovalves to hum when energised. It should stop 30 seconds after all the doors are closed.
DS21
You are spot on, I've just come in to say it's stopped. Thank you
- x 3306
I know of somebody whose electrovalves were humming. He then taught them the lyrics, and now they sing along with the radio instead!
- x 5673
- x 5673
- x 5673
- x 5673
Strangely enough I read that article - was aware of the phenomenon since way back but I wonder if it is this I can hear in the quiet hours during the night - I often think it is the central heating pump running but invariably not.
I like the thought of being sensitive to microseismic waves.
Probably ball locks though.
- x 8378
Grain of truth in this... You can hear the electrovalves singing on the wireless by switching to the longwave band and tuning down to around 170KHz...Hell Razor5543 wrote:I know of somebody whose electrovalves were humming. He then taught them the lyrics, and now they sing along with the radio instead!
There you will hear them switching in and out as you corner....
harryp
- x 73
... and when you get bored with that, if you use hearing aids and set to "loop", you can hear the injectors firing - and cutting out on the over-run.
Oh for a decent hobby, when the cars let me...
Regards, Harry
2000 Nov Forte HDI 110 hatch in Wicked Red; currently SORN
2000 Mar Exclusive HDI hatch in Quartz; currently SORN
2013 C4 Picasso Excl E
Peugeot 207cc 1.6 Roland Garros
- x 8378
That's useful to know Harry!harryp wrote:... and when you get bored with that, if you use hearing aids and set to "loop", you can hear the injectors firing - and cutting out on the over-run.
harryp
- x 73
Does mean that you don't hear much else tho'
Regards, Harry
- x 2001
Pardonharryp wrote:... and when you get bored with that, if you use hearing aids and set to "loop", you can hear the injectors firing - and cutting out on the over-run.
harryp
- x 73
Ooh Alisdair.... and your lovely Diaramas
Regards, Harry
- x 2001
Stopped that now, eating more carrots and AllBran
