Bergen Xantia Activa CT
HansNOR
x 7
Unread post by HansNOR »
Edit: Forgot pictures of the car so i put the ones i got in here :)
Made a deal on a 1999 Xantia Activa this summer but did not get it home until the 22nd of this month (december). At the moment its on the lift in my uncles garage sharing space with two Citroen SMs and a Dyane, and in my mind that is great company for my car to pick up its second wind .
The car has been properly loved in the past until she (yes, this is deff a she) started marking her territory green ..
As far as i can make out the car has been sitting for at least a year and a half . .. outside.
The interior has not suffered and the leather is nice and the only mold detected was in the trunk beneath some MDF put there for stereo purposes. the mold was dry so i'm thinking its been something leaked there in the past as it was underneath the MDF.
As to the exterior the rain here in Bergen has kept it clean :p but it has started to turn green. The underside of the car could be worse considering the car spent outside, but luckily it was gravel and not dirt . Either
way there are some rust issues to be met.
In the past the car has been driven on local race tracks around the Oslo area, and consequently the car has received some additional horsepower at some point. According to the previous owner it was dynoed at 194 bhp.
I know the previous owner has some goodies stored away in his garage so at some point i need to get over there to check it out. Bigger Turbo etc . .
From what i've found of faults its the leak from the rear and a leaky radiator in the front. The brake discs could use a quick turn in the mill . will measure how thick they are first.
I will link a picture to the leaky part in question as i do not know what it is called .
the "collector" with return feeds and pressure feeds has what looks to me to be a crack where it pushed out the connection for the return feed .
the oil bleeds from what appears to be an inset being pushed out. It is not that much of a bleed since its a return lead.
Got no clue thou what this is called :)
Borrowed a picture so everyone understands where this sphere is located :
HansNOR
x 7
Re: Bergen Xantia Activa CT
i see i need to do something about the pictures .. hmm
x 1476
Unread post by xantia_v6 »
I managed to fix the image links. My method (there are probably others) was to open the url that you linked in a browser, right-click on the image and select "copy image url" (or similar) and paste that into the image link on the forum.
HansNOR
x 7
thank you. thats usually what i do too when i think of it, but this time i only copy pasted the url . Thank you for helping out :)
BTW: the part above is located at the rear right just in front of the Activa Ram Bar
x 2004
Unread post by Stickyfinger »
Hello and welcome fellow ACTIVA owner
Join this : https://www.facebook.com/groups/8583165 ... p_activity
Look here: http://xantia.olympe.in/ (Google Translator helps)
These may help with your present situation
http://www.frenchcarforum.co.uk/forum/a ... itesearch=
http://www.frenchcarforum.co.uk/forum/v ... hp?t=41919
xantos
x 10
Unread post by xantos »
Congratulations!
I would recommend doing these things before you hit the road:
- brake doseur "hat" seal repair (you don't want to have a puddle of LHM under the drivers foot)
- octopus repair / make a new one (you don't want to have a puddle of LHM under the car)
- steering valve reseal
- HP pump reseal
- activa cylinders reseal
Just my experience with Xantias...
Xantia Break 1.9TD (jammed b****!)
Xantia Activa 2.0 TCT + LPG (1998) (peeing b****!) RIP
Xantia Activa 2.0 TCT (1998) (burnt b****!)
Xantia Activa 3.0 V6 (1998) (not a b****! yet :-D )
C4 Exclusive 2.0 HDi (gear shifting b****!)
x 8428
Welcome from a fellow Activa owner :D
The leaking component is the Hydractive electrovalve and it is now a common problem. It is leaking die to dissimilar metal corrosion; the body of the valve is made of light alloy and it sits on a steel block..
Spares are now getting increasingly rare but the bad valves are fixable with a bit of lathe work...
Have a look at this thread for full details...
x 2004
CitroJim wrote: It is leaking die to dissimilar metal corrosion; the body of the valve is made of light alloy and it sits on a steel block..
It is leaking because it keeps damp in those areas (by dust and mud etc).....only then will Aluminium corrode. WAX the area
(Jim, I know I am being pedantic but Al/steel is passive until you add water, only then do we have problems. Painting is worse as it traps the water and concentrates the rot. Wax protection or anodising, as you know I use battery protection wax spray for that, it is cleaner to wipe off than dinatrol :)
I never paint the joint areas if its a large item )
wurlycorner
x 271
Unread post by wurlycorner »
xantos wrote:Congratulations!
- HP pump reseal
Only done one of those things (pump) on mine - and that didn't last a year, damn thing!
:roll: I guess more joyous jobs still to come on it when I've got all the rest of the stuff finished...
Iain
CX DTR T2 Safari (silver)
x 8428
Stickyfinger wrote: It is leaking because it keeps damp in those areas (by dust and mud etc).....only then will Aluminium corrode. WAX the area
Absolutely agreed :D
HansNOR
x 7
Thanks a bunch. This sort of feedback was what i was hoping and dreaming of :)
My uncle which lends me his garage and lift is a Citroen Tech by trade but has now given his gift over to teaching and writing educational books for up and coming mechanics . When i say my uncle it either makes me sound very young or him very old ... well. Its only five years between us , him being the eldest at 45 :)
Anyways. It means i can get good help, which i do, but id rather hold my own as much as possible so he can fiddle with his SMs . (need quite a lot of fiddling ^^ )
So thanks a lot for taking the time to comment and adding links. I know you guys have probably answered the questions repeatedly already.
and since i ramble on. .. i really am so thrilled that i got my hands on an Activa. Never been many of them on Norwegian roads - and some have died on racetracks due to heavy footed and inspired driving :p
French Car day 2007, at 27:14 there is some footage of the above crashed Xantia
French Car day 2007 footage shot from the Xantia that later wrecked. The car that I've bought is actually briefly seen at 9:40
digital cams sure has become better when u see 9 year old digital footage :p
HansNOR
x 7
ok great. so did the repair work Jim. There was no feedback , and given the thread is from 2012 and u recommend it i guess it did ? :)
i will remove the electrovalve and at the same time try to source a used one locally. Never hurts to have a spare.
x 8428
To be honest, my repair has not been tested yet as I'm still patiently waiting for a suitable (local) test-bed to try it on!
No reason it should not though...
HansNOR
x 7
i saw from my introduction thread mentioned that one should drop the subframe or hack the boot floor to gain access. . I'm a big fan of modding to gain access as that is something i know from my vw aircooled cars .
I only wish i had a donor car so i could make an oversize lid - or do some of you mold lexan etc as a lid ?
HansNOR
x 7
Stickyfinger posted these nice pics in another thread. ill post them here for my own convenience :)
Someone mentioned that this was the bootfloor from a mk1 and that the mk2 has some differences ?
