Hi All,
A leak has started from the matrix hose plastic housing at bulk head.
Can't see where as its behind matrix hose.
I think I shall glue into place.
Kenny
Leak!!!!
KennyW
- x 163
Leak!!!!
C3 1.4 petrol (SWMBO)
citroenxm
- Fallen Hero
- x 70
Re: Leak!!!!
NO Kenny, dont glue it, because of you ever need to do the matrix you will never get the pipes out, they can be hard as it is and often break off!!
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
KennyW
- x 163
Re: Leak!!!!
Thanks Paul,
After Christmas I will have a look at the problem. I hope it's not the matrix. I might be able to glue the crack and change the piping so it doesn't happen again.
Kenny
Kenny
KennyW
- x 163
Re: Leak!!!!
Hi All,
The leak would appear to be a poor seal between matrix and hoses. The rubber o rings were not in the matrix housing but on the plastic insert.
Will get new seals and try again.
Kenny
Kenny
KennyW
- x 163
Re: Leak!!!!
Leak fixed!!!!!!!!!!!!!!!
wurlycorner
- x 272
Re: Leak!!!!
Iain
CX DTR T2 Safari (silver)
Iain
KennyW
- x 163
Re: Leak!!!!
I think it was engine vibration and I had smeared a little grease onto o rings.
They combination of both as resulted in pipes moving and thus the leak.
- x 8143
