C5 Headlight issue
Bandit12
x 12
C5 Headlight issue
Unread post by Bandit12 »
Hi Guys
Started getting an intermittent problem with the drivers headlight. While on normal dip beam I've noticed that it sometimes flickers and goes out, particularly when warming up in the first 10 -15 minutes of use. Had a look under the bonnet but found no obvious wiring issues. Is this a sign the bulb is on its way out? If so then what type does it take as an internet search threw up H7s and another kind which I can't recall the number of the top of my head. I've heard that they take a funny kind of bulb and they can be a sod to change.
Any tips are appreciated
Bandit
2002 Citroen C5 2.2Hdi exclusive estate (sadly gone) :(
2009 Citroën C5 X7 2.0 hdi (136bhp) exclusive estate (Oh wow what an upgrade) 8-)
x 5671
Re: C5 Headlight issue
Just done mine - H4 for the main/fog and H7 for the dip.
They are awkward to change and I can do it without but find it simpler to remove the bumper.
It does sound like a loose connection though so removing the unit and giving it a good clean up might fix that.
I always clean the contacts and give them a shot of contact cleaner to inhibit corrosion.
If you need replacement bulbs, I found that Phillips X-treme vision to be very good.I was going to use Osram Nightbeakers but read that the filament placement can be a bit random leading to a poor beam pattern while the Philips ones seem to be superior in this regard. Haven't made a direct comparison
Got mine from Amazon at a reasonable price.
x 1056
Unread post by wheeler »
With it being an exclusive will most likely have xenon headlamps ?? Do they have washer jets on the bumper ?
If it is xenons then flickering is a sign of the bulb failing.
Bandit12
x 12
Thanks for the tips guys and yes wheeler it is an exclusive with the washer jets under little plastic covers on the front bumper. One ot the covers has dissapeared so I will need to source a silver replacement-Doh. but thats another issue. Typical headlight bulbs started messing about as Ben82 popped by only 2 weeks ago. He has recently changed his bulbs he offered to show me how to do this but it was dark when he showed up and I said not too worry as the bulbs will last for ages yet!
I'll look on amazon and find a set of H7s
Bandit
x 5671
Sorry, didn't see it was an exclusive so the H7s are of no use to you.
Most likely these bulbs will be what you will need.
Wait for someone who has the same setup to confirm before buying though and beware of cheap ones as they don't seem to have the right characteristics nor longevity.
vborovic
Locked user account
x 40
Unread post by vborovic »
So, you have headlight washers but regular halogen headlamps then? ... that's what wheeler was asking about ...
Regular (halogen):
Xenon:
Bandit12
x 12
Hi guys sorry for the delay in relpying but been away for xmas and new year with limited internet access.
Errm I'm unsure if that photo is what I have so I took a photo of my own.
oh pants! I've got windows 10, how do I add a photo? tried the image thingy but no luck. tried the copy and paste from album but it wont paste :?:
Bandit
x 5671
Have a read of this, tells you all you need to know
