C5 2.0 hdi 8valve intercooler.
lexi
x 134
Unread post by lexi »
What is the purpose of spigot and hose appendix at the top of Intercooler?
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
citroenxm
Fallen Hero
x 70
Re: C5 2.0 hdi 8valve intercooler.
Unread post by citroenxm »
its for the Pressure Sensor... The Pressure sensor that senses turbo pressure so the ECU knows when to open the wastegate.....
A very sad...
1994 XM 2.1 d auto
lexi
x 134
Any pics of the set up as I don't have anything there!
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
lexi
x 134
Managed to get some images up from google. That sensor sits limp in my battery tray. I seen it in there and didn't know what it was. Will need to investigate.
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
x 5674
Where it should be.
lexi
x 134
This looks more like mine. http://www.406oc.co.uk/viewtopic.php?f= ... 4&start=30
Does the tiny air spigot hose connect to the sensor then? I see no male spigot on those sensor pics? Need to check tomorrow. The sensor has the male and female plug connected IIRC, just not mounted on bracket.
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
x 5674
lexi
x 134
Thanks all. I never saw a spigot on my sensor...........as it is sheared off :rofl2:
2 questions: What does that sensor do to the system/engine when not connected and operating. I have no warning lights.
Does any one have the part no.? It is the Denso sensor. VIN No. VF7**************[VIN obfuscated, can be read by forum staff]. I don't see it on Service Cit.
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
x 5674
It is the MAP sensor.
I was told I needed a new one when the MAF failed - £40 at the time.
Turned out I didn't at all.
Not clued up to what it actually does but suspect it prevents overboosting.
citroenxm
Fallen Hero
x 70
I said I think above. It monitors the inlet pressure after the turbo so the ecu knows if its over boosting or not... the turbo will either not work.. or constanlty overboost putting the car into limp mode or just not boost efficiently..
A very sad...
1994 XM 2.1 d auto
lexi
x 134
Got to be ordered then. Proper Denso items on Ebay for £40.
In an old post, Wheeler said it is not a "true map sensor", but a boost pressure sensor.
Thanks gents.
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
