Which gasket goo?
Jaf
x 42
Which gasket goo?
Unread post by Jaf »
Hi folks. I'm half way through cambelt/ cam cover gasket/ cam seal/ water pump/ crankshaft seal change. Not going too badly but I'm not sure about this inlet pipe, there's no gasket but does look like old gasket goo. If its a rubber seal it's very, very knackered. Blue goo ok?
Thanks!
Fred, a silver 1998 1.9TD SX Xantia.
Gwin, a white 1994 1.1 AX.
lexi
x 133
Re: Which gasket goo?
Unread post by lexi »
Any goo that is friendly to sensors will do. It tells on the tube.
If no sensors up or downstream then no worries what you use. Any old RTV.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Jaf
x 42
Thanks! Having day off. Back to it tomorrow.
