406 V2 Ew10J4 RFN engine : key light on dash board.
toh
x 5
Unread post by toh »
Hello world,
I have again a problem with my peugeot .
The engine could not start because of the key light on dashboard. Then, I replaced the battery as some said on the web. But the light comes again yesterday and engine could not run.
This morning, it could start as nothing happen.
Could I have suggestion on this.?
LOVE is All AROUND.
x 1055
Re: 406 V2 Ew10J4 RFN engine : key light on dash board.
Unread post by wheeler »
Do you have a spare key you can try?
toh
x 5
wheeler wrote:Do you have a spare key you can try?
That's is a big problem. I have only one key. This is the third hand car.
Yesterday, the car was started normally with no key light at all.
I am afraid of the coming back of key light. :?
LOVE is All AROUND.
x 8411
Hopefully it was just a 'one-off' event Toh [-o<
x 3296
I would suggest you get hold of the security code (you may have the card with the car, otherwise a visit to Peugeot may be in order, with proof of ownership), and then do a little digging. It might (only might, not definitely) be possible to (once you have a blade cut for it) code a second hand key to the car. This was possible on Xantias, but NOT possible on the C5. If somebody has a Lexia system they can help. Normally a new key, coded to the car, can set you back around £150! Once you have a spare key you can breathe more easily.
DHallworth
x 161
Unread post by DHallworth »
This happened to a friend of mine with a Peugeot 407. The transponder chip inside the cheap had broken free from the PCB. I resoldered it with a very very fine tipped soldering iron and it never gave any problems again :)
David.
'98 Xantia Activa V6 :-D
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
toh
x 5
Hello friends,
Thank you all;
It comes back again. A good thing was it came during the car was in home.
Then, I plugged the car with PPS and try to re-program it but PPS said the code is incorrect.
I took the code from security card which are four capital english letters.
please..
LOVE is All AROUND.
toh
x 5
Dear all,
I cleaned the connector of the immobilizer receiver at the key holder.
I think now the problem is removed.
LOVE is All AROUND.
x 8411
Toh, that's excellent news :D
toh
x 5
Thank you Jim,,
Happy chrismas.
Here is an imobilizer receiver.
LOVE is All AROUND.
