C5 Mk1 TPMS upgrade
BSC
C5 Mk1 TPMS upgrade
Unread post by BSC »
My last car had TPMS, so I appreciate the benefit. My 2004 C5 doesn't have it, but given that upgrades to the C5 are so easy, I wonder if it's possible to add TPMS? I'm guessing that an ECU and wheel sensors will be required, but where does the TPMS ECU live? Anyone performed this upgrade?
Cheers
David
x 3304
Re: C5 Mk1 TPMS upgrade
You will also need an exciter (or take it somewhere where they have one), as the system need to 'learn' each tyre.
x 1056
Unread post by wheeler »
I dont believe the mk1 has a seperate ECU as its just a very basic system. The sensor signals are recieved by the com2000 unit. Ive never done it but in theory it should just be a case of fitting the sensors, reconfiguring the BSI to have tpms then activating & programing the sensors.
The mk2 has a totally different setup & has a seperate ECU.
qprdude
x 14
Unread post by qprdude »
Where would the warning be on the dash?
I think the X7 TPM, ECU resides in the spare wheel well in the boot.....possibly
Rick.
2013 Citroen DS 5 D/Sport
BSC
Thanks for the responses!
I have found sensors on Aliexpress, so I'm going to give it a try. I'll let you know the outcome.....
Cheers
David
x 1056
qprdude wrote:Where would the warning be on the dash?
The warning message comes up on the central display, would only work fro the level 2 dash upwards.
qprdude
x 14
Cheers for that, I just wondered how it was going to be displayed, and where.
Rick.
Fake Concern
x 65
Unread post by Fake Concern »
On my C4 VTS (which I think is similar)I no longer have the wheel sensors as I have aftermarket wheels. I have toyed with replacing them, but was unsure if they'd fit in the new wheels. I am not sure if the C5 is the same as the C4 in that mine has sensors clipped to each wheel arch liner and wired into the loom. (I discovered these when I had to replace the front liners due to a meeting with a small furry animal) I imagine this part would not be fitted to a lower spec model and would be very expensive to add. Have you checked if yours needs these?
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
Would it not be simpler to use Tyrepal or similar. I have them fitted to my caravan wheels and the temperatures and pressures of both tyres are shown on a small device attached to the dashboard. Any loss of pressure is indicated by an alarm initially.
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
Fake Concern
x 65
JohnD wrote:Would it not be simpler to use Tyrepal or similar. I have them fitted to my caravan wheels and the temperatures and pressures of both tyres are shown on a small device attached to the dashboard. Any loss of pressure is indicated by an alarm initially.
That sounds very good, but if the OP is anything like me, he will want the inegrated system!
BSC
Fake Concern wrote:On my C4 VTS (which I think is similar)I no longer have the wheel sensors as I have aftermarket wheels. I have toyed with replacing them, but was unsure if they'd fit in the new wheels. I am not sure if the C5 is the same as the C4 in that mine has sensors clipped to each wheel arch liner and wired into the loom. (I discovered these when I had to replace the front liners due to a meeting with a small furry animal) I imagine this part would not be fitted to a lower spec model and would be very expensive to add. Have you checked if yours needs these?
Hmmmm. I'll have to have a look?
David
BSC
Yes, I'm afraid I'm a bit of a nerd. Integrated all the way. :roll:
Cheers
David
Fake Concern
x 65
Here is a pic of it on the C4, it clips to a moulded lug on the arch liner
x 1056
Those recievers on the c4 are fitted to the mk 2 c5 but not the mk1. Different system.
Xantidote
x 5
Unread post by Xantidote »
I must be out of step with you guys, as I don't want TPMS (and some other technology stuff) - just more to go wrong :( I've driven for 50 years without it, and the likes of ABS. Aircon might be nice to have in the winter.
Have I seen reference to TPMS being included in the MoT if it's a standard fitment - just another expenditure when it needs fixing :(
Martin
