Xantia 1.9TD diesel smell
aerodynamica
x 215
Unread post by aerodynamica »
Hi all, I'm loving my current xantia TD sinker and I've done a fair but of work to it already but lately I am noticing a strong smell of diesel after its been running a while. I.e. After a trip then stop and get our and there's a diesel smell pretty obvious. No sign of any leaks and ive had the covers off the diesel pump to check for oozing out at the pulley seal.
Injector spill offs are new recently
Any ideas or known faults?
Graeme M
chinkostu
x 30
Re: Xantia 1.9TD diesel smell
Unread post by chinkostu »
With the engine off prime it using the bulb and watch the return line where it runs behind the turbo piping and down the bulkhead, if theres a leak there you'll soon see it. Mine wasn't obvious until I did this as it used to stink but the area wasn't completely obvious as the hose had perished on the inside of the bend!
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto :oops:
1996 306 1.8 XN Auto :?
1996 Fiesta 1.3 #-o
aerodynamica
x 215
I'll look at that thanks
Hmmm fuel leaking next to hot turbo...
Graeme M
chinkostu
x 30
Luckily its the air inlet rather than the exhaust outlet ;)
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto :oops:
1996 Fiesta 1.3 #-o
sparksie
x 33
Unread post by sparksie »
Cit has been doing this, ever since I got her.
Nobody has been able to find the source of the smell and she never disgraces herself by either piddling on the floor, or failing to start.
I'll have a look in there one day when the weather is safer for open bonnets.
Sparksie
2000 Xantia 1.9TurboD
aerodynamica
x 215
That's my other problem- it's too dark to have a purpose butchers at it. Still runs fine
Graeme M
chinkostu
x 30
Economy still ok?
Usually if you can smell it when stopped it'll definately be leaking out somewhere. It's quite a distinctive smell! Your leakoffs definately on tight too?
Otherwise check the filter housing isn't leaking
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto :oops:
1996 Fiesta 1.3 #-o
aerodynamica
x 215
Yes will do - the car has been parked up for 3 days while I was away and after driving home this evening I didn't notice any diesel smell. Anyway, might get a chance to investigate this weekend
Graeme M
aerodynamica
x 215
chinkostu wrote:With the engine off prime it using the bulb and watch the return line where it runs behind the turbo piping and down the bulkhead, if theres a leak there you'll soon see it. Mine wasn't obvious until I did this as it used to stink but the area wasn't completely obvious as the hose had perished on the inside of the bend!
Found it! It's exactly as you describe AND the split it on the inside of the curve. I think it is heat hardened due to the exhaust heat and exacerbated by the amount of movement in the engine mountings
Not sure about the fixing of the upper under the leak as it looks like it changes to a semi rigid pipe under neath but before that the two diesel pipes look like they're moulded together in a fixing that also serves as thepoint for the plastic clip to hold it to the bulkhead. Not clear yet if it's separable without affecting the diesel supply pipe Next to it
Graeme M
chinkostu
x 30
It runs from the top of the pump under the LDA then between the intercooler hoses, its not awful to change out. There is a hose clamp where it bolts onto the bulkhead that i disconnected mine at then ran a new run up to the old pipe. The problem is its quite a snug fit behind there to refit everything.
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto :oops:
1996 Fiesta 1.3 #-o
aerodynamica
x 215
Cheers, it's all done - replaced from the connection on the bulkhead up to the pump. The original swan neck where it split was replaced with a lengthened section routed closer to the diesel feed pipe next to it. Well slack enough to take the engine movement tho I do need to replace the lower mounting I think.
Graeme M
chinkostu
x 30
Pretty much what i did except i fitted a barb so i've got a good 10cm of slack just in case. Keep meaning to tidy it up!
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto :oops:
1996 Fiesta 1.3 #-o
aerodynamica
x 215
here's a view of the area in question. Turbo pipe removed for clarity.
So if you're getting diesel smell after switching off then check here.
Cheers chinkostu for the advice!
Graeme M
chinkostu
x 30
Much neater job than mine too :rofl2:
No worries man, it boggled me for days and your symptoms were exactly the same so it was worth a shout. Seems this pipes more and more likely to split nowadays :(
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto :oops:
1996 Fiesta 1.3 #-o
aerodynamica
x 215
Haha that was a 'before' picture! It's the neatness of the 1993 assembly line at Rennes-la-Janais, But the repaired pipe is now routed further outwards (towards the sphere area) and routed down to the connection with the diesel supply pipe.
A previous owner fitted a turbo boost gauge - works well and lots of fun but I noticed the feed pipe for the gauge (comes off the bosted pipe to the fuel pump diaphragm UFO) was actually a reall long pipe and I reckoned this would cause the overall inlet volume to be fairly increased and would affect the boost curve so I shortened the pipe and lo, it's actually tightened up the performance.
Anyway, 24 h after the new fuel pipe and no smell of diesel so success!
Graeme M
