New crankshaft seal leaking
x 8151
Re: New crankshaft seal leaking
red_dwarfers wrote: The XM also has an oil leak...suspected crankshaft seal but on the gearbox side! That's sitting on the drive awaiting some warm weather!
Seems you're plagued with oil leaks at the moment Kev :evil:
Is that leak on the XM from the engine or gearbox? Easy to tell by the smell of the oil...
red_dwarfers
x 58
Unread post by red_dwarfers »
It's engine oil! I suspect its one of the two long thin sealing pieces around the bearing cap as the crankshaft was reconditioned.
At least the G and 605 are leak free...apart from the minor 605 radiator leak. Damn!
Kev
'19 C4 Cactus 130 Flair
lexi
x 134
Unread post by lexi »
If the fine wet and dry does not polish it out, then another option is an SKF Speedi sleeve.
The double lipped seal can be tried for at a bearing specialists.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Bob L'eponge
x 8
Unread post by Bob L'eponge »
red_dwarfers wrote: Do these PTFE seals look visibly different?
Yes, very much so. For one the seal is held by engine oil pressure alone, so there is no spring to push the lips of the seal onto the shaft. They require much more careful handling on assembly than a traditional seal.
http://www.skf.com/binary/tcm:12-243698 ... 243698.pdf
http://www.elring.de/fileadmin/Dateiabl ... glisch.pdf
http://www.engineaustralia.com.au/~engi ... /SB035.pdf
x 8151
Some very interesting links :D Thanks for posting them!
x 2943
For the seal try the bearing companies, see if you can find a seal half the thickness and fit two so that they're running on different places on the shaft.
