Hello guys,
I have found water dripping, right in between the seats ,just behind the gear selector lever and .
I figured out the water is coming from the aerial in the roof.
What is the best way to approach this little leak and fix this?
I can only assume removing the aerial and reinsulating it properly?
Is there a how to remove the aerial? I do not want to make a mess of the head lining.
Cheers
Vasilis.
Water leak in the cabin?
kentc5
Current Cars:
Citroen Xantia 3.0 V6 Exclusive ('98)
Alfa Romeo 166 2.0TS ('03)
Audi A6 C6 2.4 V6 SE ('05)
BMW 735i Individual M-Pack ('00)
Lexus GS300SE Navigator ('98)
Toyota Prius T-Spirit ('04)
isisalar
- x 3
Re: Water leak in the cabin?
If you have a sunroof, access is quite simple through the removable panel between the sunroof and the windscreen. I'm assuming it's the V6 exclusive Xantia.
J reg 1.9d auto BX first Citroen
M reg 1.9d auto Xantia lx
N reg 1.9 td Xantia VSX Estate
T reg 2.0HDI Xantia Exclusive Estate Present car
M reg 106 diesel red
L reg 106 diesel white
02 Saxo 1.1i desire wife's present car(sadly now very ill cambelt gone- Doh)
kentc5
Yes it is the V6 Exclusive Xantia.
But no sunroof... to the better or the worst I guess lol.
Does the lack of sunroof makes things harder
Current Cars:
kentc5
I found this...
http://www.frenchcarforum.co.uk/forum/v ... hp?t=36759
I will follow it and report back
Current Cars:
Perhaps this would be an easier way to go. I always used Comma seak'n seal but it's no longer available, this is an alternative from a different maker.
http://www.captaintolley.com/
- x 1240
Don't know if the Xantia is the same but I have had this problem with XM.'s. You get the the aerial by removing the interior light, its quite simple to remove it, give it all a good clean then smear some waxoil on the underside of the mounting and refit.
- x 8457
No, sadly not as simple as an XM Peter, the Xantia interior lights are in the B pillars. The only access to the aerial base on a non-sunny S2 is to have the headlining down. That's not such a hard job, just have the sun visors off and the front grab handles and pull back the door rubbers and it'll drop far enough at the front to give access...
- x 1240
Ah right, thanks Jim
. Never had a Xantia, I thought if I was going to have all the hassle of a hydropnumatic I might as well get the biggest one.
- x 8457
Good thinking PeterPeter.N. wrote:I thought if I was going to have all the hassle of a hydropnumatic I might as well get the biggest one.![]()
To be honest, after your XMs I think you may have found the Xantia just a tadette disappointing...
