For years i perfected the balancing trick, and i was not happy to be shown you didnt need to
Galvanised wheels?
vanny
the wheel bolts dont hold on the trims, the trims hold onto the bolts. Imagine my anger when after years of taking a wheel off, then carefully holding the wheel and trim carefully in alignment then putting the bolt on (requiring 3 hands) i found you could put the bolts on naturally then smack the trim on after!
pwatson
"the wheel bolts dont hold on the trims, the trims hold onto the bolts"
That's a fine distiction Vanny! And I was always aware of the fact that the trims went on afterwards with a firm push - every time I went for new tyres I told the fitter this as they did the balancing trick and all almost invariably replied that they had been doing the balancing trick for years also!
