Leaky fuel, Xantia
Jaf
x 42
Leaky fuel, Xantia
Unread post by Jaf »
Hello. Fred has been getting harder to start. Whilst looking around at leak off pipes, primed the fuel and found both the fuel filter drain leaking and a strange white plastic bung on the left of the the fuel filter housing leaking. Only leaks when priming, and the car then starts well.
Can I get seals or new drain screws? [-o<
Thanks.
I have got photos but think I would need a degree before managing to post them.
Fred, a silver 1998 1.9TD SX Xantia.
Gwin, a white 1994 1.1 AX.
x 5688
Re: Leaky fuel, Xantia
Jaf
x 42
Ok maybe that worked. Taken from above the fuel filter housing, the leaky bit looks like a plastic bung. Shown in the pic, centre but low down, with the orange seal pointing to it. The bung has 2 little arrows on each end. Looks like the bung is where the fuel pipe goes into the filter housing.
