I just bought today a Xantia 3.0 V6 Exclusive
Jan-hendrik
Re: I just bought today a Xantia 3.0 V6 Exclusive
Unread post by Jan-hendrik »
Thirded! I had a run-in with the stuffed shirts on that site,
So far I haven't had those run-ins on 'that site', but I have had the displeasure on a Dutch XM site, so I know how that feels. Thank ya all for welcoming me here :-D
x 8351
No stuffed shirts on here Jan I'm pleased to say :-D
Jan-hendrik
V6 pumps are rare as hens teeth, DO NOT wreck it :)
I have acquired a pump with the number 092735 and date 07/98. It was advertised as new but appears to have been rebuilt. Outwardly it has all the characteristics of the 4007 Q9 pump with the square 4-bolt flange. The XM parts list does not have the 092735 part number. This number seems to relate to Xantia models. Does anyone know if I can use this pump to replace my 4007 pump?
I have posted the above also on the Citroen XM forum, but I think there are more members with Xantia models here. Maybe you could help me, Jim? Anyone's input very welcome, of course!
kentc5
Unread post by kentc5 »
Well I am puzzled! lol
Every memory button I am pressing ... it brings up the number the memory button has ... (ie memory one types number 1, memory two number 2... and so on).
The problem is the 4 digit code has a 7!!!??? How on earth am I going to type a 7?
Current Cars:
Citroen Xantia 3.0 V6 Exclusive ('98)
Alfa Romeo 166 2.0TS ('03)
Audi A6 C6 2.4 V6 SE ('05)
BMW 735i Individual M-Pack ('00)
Lexus GS300SE Navigator ('98)
Toyota Prius T-Spirit ('04)
x 8351
Jan-hendrik wrote: This number seems to relate to Xantia models. Does anyone know if I can use this pump to replace my 4007 pump?
Hi Jan,
I'm very happy to confirm the V6 Xantia pump is identical to the ES9 V6 XM pump and the two can be freely swapped between... I have never noticed any significant difference between the two and whatever it is has no effect on mounting or performance as far as I can tell...
x 695
Unread post by Mandrake »
You must have the wrong code because on that model of radio you can only enter numbers from 1-6 as it is direct entry (press the number you want) rather than each button cycling the number of a particular digit from 0-9 like the Series 1 radios.
x 8351
Kent, on the radio code side, you're looking at instructions for a totally different (the S1) wireless.. There you just keep pressing the button and the number increments up for each press...
The S2 wireless is different for code entry and for the life of my I can't now recall how it's done as I've only ever done one S2 wireless in my life... Done thousands of S1 ones though...
x 695
On the S2 you hold down BND until it says code then directly enter the 4 digits by pressing buttons 1-6, which means the code cannot have digits other than 1-6.
kentc5
That is correct I press the band button and it enables me to enter the code (two failed attempts and then it locks)
I am certain this is a 7 lol.... that's brilliant the car has one owner and citroen prior to that. Yet someone managed to get the manuals mixed up! LOL
Current Cars:
Jan-hendrik
You made me very happy with that news, Jim. Thank you :-D
elma
x 287
Unread post by elma »
That Radio and that manual are not a match. Good news about the pump though.
kentc5
Will I need to get the serial number of the radio to get the code retrieved?
Current Cars:
elma
x 287
Yes, you have half a chance of getting the code online using the numbers on the back of the radio. Citroen can help you for a fee, but if the head unit isn't the original they may not be able to.
kentc5
managed to take the radio out and get the serial number.
I jet-washed the engine (like I have done with all the other cars I always had) but the Xantia being a Xantia ... now will not start lol. It ran for about 5 mins then died when I touched the accelerator. It will not start since.
So I let her dry this glorious sunny day hehe.
I only managed to lift her all the way up and all the way down, while she was running and there was no LHM coming out of the pump (this was part of the reason of why I washed her).
Current Cars:
DHallworth
x 166
Unread post by DHallworth »
Here's a copy of the pages from my Activa's Radio manual that'll show you how to enter the code.
I think that's the wrong code for your car as like the others have said, it can't have a 7 in it. If that's written in the back of the radio book, there's also a good chance it's the wrong code as it's likely for the radio in the Series 1 car that the book belongs to.
Contact your local dealer and ask them to get it, sometimes they charge a tenner, others they don't. It'll certainly be easier then bricking the radio.
With regards to the hydraulic leak, it can be done in situ but it's not easy. Personally, I'd rather persevere and do it where it is rather then removing the pump. It tends to only be the top seal that leaks so replacing only that one will probably see you home and dry. On the XM V6 it's a 5 minute job, the Xantia V6 its a bit more fiddly due to the engine bay being smaller.
David.
'98 Xantia Activa V6 :-D
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
