C5 Main beam problem
1900sr
Unread post by 1900sr »
If this has been covered I apologise, but I couldn't find anything on a search here, or on Google.
I've got a 2002 C5 Estate, and as of last night it's seems to have developed a fault with the headlamps. The main beam intermittently turns itself off. Basically put the main beam on, and quite often a few seconds later the car goes back to dip beam. When you turn on everything seems normal, the blue light on the dash comes on as it should, and when they turn off it's just as if I've turned it back myself, the blue light goes back out and the car goes back to dipped beam.
Has anyone else had this, or got any ideas please?
qprdude
x 14
Re: C5 Main beam problem
Unread post by qprdude »
Comms 2000 unit. BSI reset. battery on the way out. Plenty threads on search. I don't have that car but these three thing seem to be a common starting point.
Rick.
2013 Citroen DS 5 D/Sport
x 1990
Unread post by Stickyfinger »
Comms200 is the "normal fault" seen for this behaviour. I would try a switch first just in case, never heard of the battery being the problem with this fault.
The is a guy who fixes them.
1900sr
Thanks for the replies. The car has been fine since, so I'm hoping it was just a glitch. If not I'll try the switch first, although I'm not convinced it's that.
1900sr
Since found the problem rears it's ugly head when the lights are on manual rather than auto setting. I did have it up for sale but can't sell it with the fault. It's going for scrap I'm afraid.
dnsey
x 19
Unread post by dnsey »
If you declare the fault, I'm sure that there are potential buyers who won't be deterred by the need for a fairly simple repair (Comm 2000 from a breaker's).
1900sr
Fairly simple repair if you've got access to Lexia to reprogramme it afterwards, as the car has ESP. To be honest I've decided to buy new and Vauxhall will give me £2000 "Scrappage" for it, and combined with the other deals available I'm going to do that.
wurlycorner
x 271
Unread post by wurlycorner »
1900sr wrote:Since found the problem rears it's ugly head when the lights are on manual rather than auto setting. I did have it up for sale but can't sell it with the fault. It's going for scrap I'm afraid.
:? scrapping a car because the headlamp switch needs swapping with a cheap used one? :?
Iain
CX DTR T2 Safari (silver)
1900sr
I'd be surprised if it's just the switch given the fact it's only a problem when the lights are on manual, works fine when the lights are on auto. Besides, those awfully nice Vauxhall people have decided that it's worth £2000 in scrappage against a new car so that's where it's going.
daviemck2006
x 496
Unread post by daviemck2006 »
Depending on which vauxhall you are buying, but our local vauxhall dealer gives from £2000 to £7000 off the price of a new one so your 2000 "scrappage" possibly leaves you worse off. Go to a different dealer and ask for a big discount off a new one the same and see what happens.
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
x 5662
Does that price include a fire extinguisher?
x 6955
:rofl2: errr... but before we get too smug .... :roll:
wurlycorner
x 271
Indeed
But of course you will always get random failures like this.
Iain
