Xantia MK2 LHD -Where is the remote lock receiver
lancia58
(Donor 2022)
x 8
Unread post by lancia58 »
Hi
Does anyone know where is the receiver ( RF receiver ) of the remote lock ? Its a LHD MK2 xantia
Zohar
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
x 8427
Re: Xantia MK2 LHD -Where is the remote lock receiver
It's in the CPH module under the dash on the passenger's side... Remove the glovebox (and possibly airbag if you have large hands!) to get at it...
lancia58
(Donor 2022)
x 8
Hi Jim
Is the CPH visible once the glovebox is removed ? In case I need how the airbag is removed ? I guess the battery should be disconnected at least 30 minutes before removing it.
x 8427
Yes, it is just visible on top of the air trunking... You will see it has the transponder module and TrafficMaster module piggy-backed on top of it...
Airbag can be removed once the glovebox is out. It is held in with many small nuts.
Yes, disconnect battery 30mins before starting work...
lancia58
(Donor 2022)
x 8
Hi Jim
I removed the glovebox and sow the transponder module. What is this "TrafficMaster module" I think that it is not fitted on my car. BTW why so many wires are connected to the transponder ? How can I check if the transponder is functioning ? Of course if the guy who installed the aftermarket transponder had not cut so may wires it was easy to check if it functions. If there any wire that I can hook a multimeter and see if it is effected once I press the lock/unlock buttons on the remote key ?
Zohar
x 8427
TrafficMaster was (is still?) a UK system that alerts the driver to traffic news by playing a message through the radio.. Yours is indeed unlikely to have it...
If the engine starts then the transponder is good. It's only a tiny box on top of the main CPH box which should have two large plugs and lots of wires going to it... The transponder only has two small plugs and few wires...
As well as the alarm, the CPH controls central locking, interior lights and ignition immobilisation (in conjunction with the transponder) as well as receiving and decoding signals from the plips. It does a lot...
lancia58
(Donor 2022)
x 8
Hi Jim
Isn't the immobilizer transponder attached on the ignition switch ? As the key has an RF ID device the transponder should be near the key . So the CPH communicates with the remote key and ( I know that each the key and the CPH communicate the code is changed and the new code is transmitted from the CPH to the key electronics) , and opens/closes the doors. BTW with the original system will the windows automatically lifted when a lock command is send from the remote key to the CPH ?
Zohar
x 8427
No, all that's on the ignition switch is the antenna to communicate with the RFID chip inside the key...
Note that the transponder, CPH and engine ECU are all a matched set and cannot be individually replaced.. All three must be replaced as a set.
lancia58
(Donor 2022)
x 8
Hi Jim
Can't you make a matched set if you using a Lexia ?
x 8427
lancia58 wrote: Can't you make a matched set if you using a Lexia ?
No, the ECUs are one-time-only programmable as a set unfortunately...
Once they're programmed, that's it for good.
If one is faulty then you need to get a set from a scrap/donor car and then for that set you must know the confidential access code so that you can train the keys and plips to the CPH using a Lexia...
It's not straightforward at all.
lancia58
(Donor 2022)
x 8
Where is the RF ID chip ? Is it part of the key electronics or is it inside that little black molding of the key ?
I think that once I tried to check it by removing the electronics from the key. If I remember well I was still able to turn on the engine with no electronics in the key so probably the RD ID chip is in that molding .
Zohar
x 8427
It is in the black moulding Zohar...
On a plip key it is in the circular black bit and you can see where it is if you look carefully...
lancia58
(Donor 2022)
x 8
So if one lost the keys his only option is going to a Citroen dealer provide the key code ( the one that comes with the car ) and get new ones from Citroen ? I guess the cost is high
Zohar
x 8427
Cost is not too bad.. I did one about three years ago... To programme the key you need the CPH confidential code and a Lexia... If you do not have the CPH code then most main Citroën dealers (at least in the UK) can supply it on production of vehicle documents showing the VIN and proof of ownership...
I'd expect this to be the case in most other parts of the world.
lancia58
(Donor 2022)
x 8
Is the Lexia able to program the RF ID chip as well ?
Zohar
