C5 Tourer Tailgate
mooseshaver
C5 Tourer Tailgate
Unread post by mooseshaver »
I'm sure my boot used to suck in a bit at the bottom when it closed. It does not seem to be doing that. And the gap on the right is larger than the left.
Should I worry? It could explain why the outside world seems so loud recently.
C5 III Tourer 2.0 HDi 163 Auto Exclusive
Gone cars.
C5 2.2 HDi Exclusive Estate auto 57. Awesome car. Sadly Could not be fixed by Citroen.
C5 1.6 HDi VTR Estate 56. Traded in.
C5 2.2 HDi SX Estate 02. Drowned in the floods of 09.
C3 1.4 HDi 92 SX 52.
Saxo 1.1 East Coast.
DickieG
Monaco's youngest playboy
x 33
Re: C5 Tourer Tailgate
Unread post by DickieG »
Sounds like the lock isn't operating, as you mention the boot on mine closes then pull's into the locked/shut position.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
vborovic
Locked user account
x 40
Unread post by vborovic »
You're talking about the motorized tailgate, right?
mooseshaver
Yes motorised. I can't manually close it all the way either. It makes the closing noise just no movement.
Not sure what I have done. I can hear it moving up and down over bumps so can't be ignored.
Gone cars.
DickieG
x 33
Have you tried using the shaft of a screwdriver on the lock clasp to replicate the ring on the bodyshell to observe whether either the lock actually "locks" or it or the ring are simply out of adjustment?
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
mooseshaver
No.t tried I notice the bit in the car move left/right back/forward if I wiggle it. Sometimes I see it move on its own when it thinks I'm not looking.
Gone cars.
old'uns
x 127
Unread post by old'uns »
check the latch ring on the car isn't loose...mine was doing the same as yours.
you can just about get an angled Torx key in to adjust it
mooseshaver
So should it not move or move less? I have seen the torx screws.
Gone cars.
old'uns
x 127
it shouldn't move.
i quickly checked mine but by hand seemed tight but obviously the motor puts a lot more effort into it.
mooseshaver
Oh thank you ever so much. I tightened the torx and now it's working!
I need to make them very tight but a quick go and it's working
Thanks again
Gone cars.
x 2004
Unread post by Stickyfinger »
Should it have some thread lock OldUns ?
old'uns
x 127
not too sure...mines never become loose again but probably wouldn't go amiss IF you can get the torx bolt out enough and get the nozzle in there?
pretty sure the chrome trim neeeds to be removed which probably means ripping out most of the trim etc so i just did it as easy as i could
