Xantia - Differences between engine mount bushes
lancia58
(Donor 2022)
x 8
Unread post by lancia58 »
Hi
I have a Xantia 16V (RFV ) automatic make year 2000. I need to replace the engine mounting bush. The problem is that it is NFP.
I found on eBay one with Citroen catalog number is 182732 and it is for Xantia TURBO DIESEL DW10TD
Citroen catalog number for the engine mounting bush in my car is 96171997 ( NFP )
Can one tell me what are the differences ( I am sure there are ) ?
Zohar
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
Old-Guy
x 24
Re: Xantia - Differences between engine mount bushes
Unread post by Old-Guy »
You don't say which of the engine mounting bushes this is; nor which auto-box is fitted (relevant if you're talking about either the bush beside the differential or that at the end of the gearbox.
lancia58
(Donor 2022)
x 8
Hi
The auto box is AL4. The it is the mount bush that is at the right side of the engine. It's is not the bush that is attached to the AL4
Old-Guy
x 24
I've just had a look on service.citroen for you. Interestingly, this bush is only used for both auto-boxes on 3 engines: -
  • XU10J4R and BVA,
    XUD9TE and BVA
    XU7JP4 and BVA
BVA = Boite de Vitesses Automatique (automatic gearbox)
I'm surprised that nobody seems to supply this (Right-hand side) bush. If all else fails, you could contact Elastomer.eu and see if they will refurbish the bush for you (it's not listed, but they do XM and CX mounts).
