This intercooler.
lexi
x 133
This intercooler.
Unread post by lexi »
Here is the oily intercooler on Donk again but cleaned up a bit. http://s126.photobucket.com/user/alexbo ... 2.jpg.html" onclick="window.open(this.href);return false;
My thinking is still that the seam at plastic and alloy crimp could be suss. If I start her up and get it revving, I suppose it is ok to spray some liquid and look for bubbles? I disconnected the bottom hose at IC and only got one tiny drip of oil from it.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
elma
x 284
Re: This intercooler.
Unread post by elma »
Apparently that pics private. I don't see a problem with using a bit of liquid to hole find, I usually use washing up liquid for that type of thing.
lexi
x 133
Library is private but usually uploads the pic I copy.
Any better?
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
elma
x 284
Much better.
Don't know why but couldn't make the last one open any which way.
I'd definitely give it some sort of leak test if you suspect it's blowing.
x 5673
Link worked OK for me James.
elma
x 284
Me too now :oops:
lexi
x 133
Bingo Elma! Soapy spray reveals big bubbles where veins go into the plastic chamber !
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
elma
x 284
Theres your fuel economy and power.
lexi
x 133
New intercooler ordered.
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Old-Guy
x 26
Unread post by Old-Guy »
My first reaction was "A bit of a leak isn't going to make much difference given the volume of air a turbo delivers." Then I remembered the effect of a split pressure sensor pipe (the one to the 'star-ship' sensor on the top of a Bosch pump) - gutless. Seemed worse than the difference between a 1.9 and a 2.1.
lexi
x 133
I don't think it is impairing economy or performance that much Guy If a new one had been big money, I may have epoxied the old one.
Got a deal on a new one at a good price.
There is still the possibility that turbo seals are less than perfect of course. Going to clean all those hoses out, fit IC and keep an eye on it for any oil collecting.
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
