Hi all.
Strange one this..
My daughter has a 2002 picasso hdi 2.0.
Went to start it the other day and ign light came on but no cranking over.
Tries again and now no ign light or electrics..
Simples methinks its obv battery but no.Batt shows 12.6 volts.
Simples methinks..Jump it..
Nope-jump leads to pos underbonnet and another on earth on engine and huge sparks!
Jump leads onto batt connections does nothing.
Mega fuses are ok..Am I missing something obvious here lol.
Theres not even any power to fuse box under bonnet.The whole car is dead but has a fully charged battery connected!
HELP!!!
Thank you for reading.
Picasso Hdi Elec HELP
Deanxm
- x 87
Re: Picasso Hdi Elec HELP
Ignition switch finally given up?
D
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
- x 1240
Still could be the battery, they can show 12v or more with no load which can drop to nothing as soon as you draw some current. First thing to check is the battery connections, wiggling them about will often effect a cure but if it does they need taking off and cleaning.
spiketheguru
Thanks guys.
Ive tried wiggling the cables and also putting booster cables directly onto the battery leads..still nothing at all.The sparks under the bonnet when I try to jump it should be a clue here I think but im not great on diagnosing electrics,looks like I need an expert..
elma
- x 287
Sounds like a break in the battery negative lead to me or a corroded fuse connection.
Can you swap the battery in the car with the jumper one to see what happens?
spiketheguru
Hi Elma
Ive tried putting another (fully charged) battery on and its still completely dead.No power anywhere no interior light nothing..Poor daughter is stuck with 2 kids and no car
spiketheguru
Is there a fuse from battery cables anywhere?
elma
- x 287
You got a multimeter?
Set it to Resistance (Ohms / ?)
One battery lead at a time check between the clamp and the other end of the lead, you should get a reading. If not theres a break in the lead.
Some cars do have a fuse in the battery lead, no idea if your Picasso does or not.
- x 1240
..also check the resistance from the negative connection to the body/engine, should be near enough zero, or check the voltage should also be zero.
spiketheguru
Thanks for your help
Im on ebay buying a multimeter so will try your suggestions.
spiketheguru
Sorted!
Got a mate to have a look and he found a faulty earth and fixed it!
RAC never had a clue where to start and just recovered it...
spiketheguru
Thank you for all the help
- x 3294
Well done for finding the fault (OK, your mate found it, but it got found, and that is the important detail), and thanks for posting up that it was found. That will help anybody who has a similar fault.
