Here we go:
WHEEL HUB - FRONT
WHEEL BEARING KIT - FRONT
= £48.00 including all taxes and delivered to my desk at work
1996 Xantia 1.9TD 290k front nearside hub replacement
romie
Re: 1996 Xantia 1.9TD 290k front nearside hub replacement
Citroen Xantia 1.9TD 1996 estate 100% veg 323k
Ford Transit Tourneo 2.5L Di 1999 165k
Yamaha R1 1999 26k
Kawasaki ZXR750 L1 1993 66k (to LPG?)
Suzuki Bandit GSF400 1992 x 2
Mountain bike, skateboards, snowboards, surfboard, longboard and feet!
Yamaha R1 1999 26k
- x 1488
Just use the best fitting of the plates from the puller kit on the inside (Don't fit the circlip first, cos then you have to take it out again - guess how I know thatromie wrote:cool, so supporting the other side of the inner race. I can use the old inner race for this?
Thanks Jim
Using the threaded puller it's pretty easy to get it square and pull in OK - well I managed it twice anyway! When you do it 'for real' make sure you take care over the ABS sensor - easy to damage I imagine.
romie
ah, right'o.
Does the hub only pull through flush to the outside of the inner race then. And so I can use a flat plate to support the inner race?
(I don't have it with me to check)
No abs on mine
(which I love)
No abs on mine
Yamaha R1 1999 26k
Yamaha R1 1999 26k
- x 8389
Yes and yes, as the inner hub stub ends up just shy of the end of the further inner race whilst its flange face rests on the outside of the nearest inner race....romie wrote: Does the hub only pull through flush to the outside of the inner race then. And so I can use a flat plate to support the inner race?
Richard, good point about the circlip
romie
fan-tast-ic!
Mucho appreciated guys
Yamaha R1 1999 26k
Yamaha R1 1999 26k
- x 1488
Took me bloody ages to get it in (must get some proper circlip pliers next time), finally got it. Then offered up the puller, and realised my mistakeCitroJim wrote:Richard, good point about the circlip
chinkostu
- x 30
Ebay? thats not badly priced at allromie wrote:Here we go:
WHEEL HUB - FRONT
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto
1996 306 1.8 XN Auto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
romie
no, no. GSF is where they came from
I wait for their 35% off, offer that pops up and get bits then.
Yamaha R1 1999 26k
Yamaha R1 1999 26k
romie
DONE!
Not such a bigger job, (ehem ~ only after some great pointers on here! :p and being able to practice on spare hub carrier)
Cheers guys!
Totally recommend going straight for the hub/bearing change in future.
Minimum key tools are:
Bearing removal kit
10lb Sledge hammer (or better an appropriate press
Cheers guys!
Bearing removal kit
Yamaha R1 1999 26k
Yamaha R1 1999 26k
- x 8389
Excellent work Romie
Those pictures give a good guide for anyone doing the job without a press and shows it can be done, albeit with the aid of a big hammer!!!
romie
cheers
Thought these terrible 2mega pixel photo's even without a flash might help someone out who's in the same predicament :/
Would have taken a lot longer without the very useful advise on here mind!
Yamaha R1 1999 26k
Yamaha R1 1999 26k
- x 8389
You know, this would be good stuff to put in the FCF Wiki...
http://www.frenchcarforum.co.uk/wiki/Main_Page" onclick="window.open(this.href);return false;
Fancy having a go?
You'll need a login which either Mike or I can provide...
Fancy having a go?
romie
erm, yeah sure. I'll have to have a read of other people contributions to get the layout. But I'll get it in there.
If I knew, I'd have got better step by step pictures!
(information is power!) xD
Yamaha R1 1999 26k
Yamaha R1 1999 26k
chinkostu
- x 30
Well done! I'm looking forward to doing this at some point, but i'll be renewing the balljoint too and hopefully borrowing a press instead!
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
romie
Cheers!
I leave the carrier in place when doing the lower suspension ball joint.
Special castle socket for joint (ebay). (also needed a deep impact 35mm socket to go on the back of the castle socket.
I put the bolt back on and tightened up (hence a deep 35mm socket), after fitting the castle socket to lock the whole assembly in place so the little castle fingers and related holes don't get wrecked while under full load but possibly at an angle.)
Loooong breaker bar. I use a 1" drive 1Meter jobbie.
Big metal welded link chain, one end attached to hub using wheel nuts other end attached to chassis to stop hub carrier rotating whilst turning the joint
Yamaha R1 1999 26k
Yamaha R1 1999 26k
