1996 Xantia 1.9TD 290k front nearside hub replacement
- x 1496
Re: 1996 Xantia 1.9TD 290k front nearside hub replacement
Yep, that's it more or less. You can bet your bottom dollar that the circlip will resist a lot more than that! Xantia bearing has to be pulled back in from behind as there is a lip at the front. It's easy to break the inner race once you have cut a slot in it - it's very hard, so cracks easily.
romie
So as a pre-run, I've stripped the non-fitting hub carrier and found it seems not to have a normal bearing in there?
It seems that the internal part of the hub carrier has been ground to take the bearings directly in the form? :/
Bit worrying as I need to fit this in mine
See how it looks like it won't fit in there?
Citroen Xantia 1.9TD 1996 estate 100% veg 323k
Ford Transit Tourneo 2.5L Di 1999 165k
Yamaha R1 1999 26k
Kawasaki ZXR750 L1 1993 66k (to LPG?)
Suzuki Bandit GSF400 1992 x 2
Mountain bike, skateboards, snowboards, surfboard, longboard and feet!
Yamaha R1 1999 26k
romie
In the above pic. I've removed the ball bearings and shoved what's left of the bearing housing back on the old hub.
There doesn't seem to be an outer race?? Just the machined surface in the inner hub carrier? :/
Am confused. Is this normal?
Yamaha R1 1999 26k
Yamaha R1 1999 26k
chinkostu
- x 30
That to me looks like the race is stuck, almost an older bearing style i think. Does it move if you try and tap it out? As the bearings are push fit anyway so that shouldnt be there
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto
1996 306 1.8 XN Auto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
romie
Here's a vid.
It seems that the bit in the hub carrier is part of the hub carrier? :/
https://youtu.be/0XXXFgHBbaM
https://youtu.be/4d6ecwIVu24
Yamaha R1 1999 26k
Yamaha R1 1999 26k
romie
uh, I've just watched em. these vids don't actually help any
Yamaha R1 1999 26k
Yamaha R1 1999 26k
romie
I've tried pressing them out with the bearing remover tool kit as shown earlier in a very agressive way, the two outer faces came out, but the inner race seems to be part of the hub carrier.
Could be wrong, but I see no seam at all? :/
Yamaha R1 1999 26k
Yamaha R1 1999 26k
chinkostu
- x 30
I guarantee if you get a chisel you could tap it out. Bearing is a standard type on servicebox
It will be chuffin tight though
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
romie
Right'o. Cheers for the confident - "it will move"! :p
I'll get at it with a cold chisel tonight. I just can't see where to attack from? :/
here's some better images I got from my work camera.
Yamaha R1 1999 26k
Yamaha R1 1999 26k
romie
or even which side to attack from?
I've removed the circlip. I take it you have to somehow knock it through from the opposite side to the circlip, and out of the circlip side, yup? :/
So hit it from this side somehow. Maybe the chisel to the inside bearing surface might give a good purchase :I
Yamaha R1 1999 26k
Yamaha R1 1999 26k
- x 1496
Yes, it comes out towards the inside edge. Think you will find it difficult to get that out TBH.... You will need to drive on the centre raised bit, but evenly all the way round as if it goes off square then it will jam solid (if it isn't already!). If you've got one of the threaded pullers you might be able to get one of the rings inside to sit on the raised bit and pull it that way. Otherwise if you have got access to a welder then run a ring of weld round the inside both above and below the raised bit, and then when it cools it should shrink the outer ring back a bit so it should come out (more) easily. In fact I would think this will be the only way you will get it, so if you haven't got a welder, then prob worth finding someone who does.
romie
ah, fantastic. Yes I've got that threaded puller, and a welder.
Puller against inner ring - check.
Extract from inside edge - check.
If no movement then two rings of weld - check.
Great, I'll try that.
Is really good I have this hub carrier to practice on! I'd have been without a car for a few days otherwise :/
Thanks for the heads-up guys, appreciated
Once this is sorted I'll have the routine for the actual job - ace
Yamaha R1 1999 26k
Yamaha R1 1999 26k
romie
it was quite confusing when I first saw it. Looked so much like it was 'part' of the carrier. Well there you go. Experience an all that :p
Yamaha R1 1999 26k
Yamaha R1 1999 26k
chinkostu
- x 30
as said, heat or hacksaw is quickest way, failing that a bloody big hammer and something that can fit across!
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
romie
haha xD
(After dicking around with a normal whacking tool, I got the hub out with a drift an 8lb sledge hammer :p )
Yamaha R1 1999 26k
Yamaha R1 1999 26k
