I've had this C5 2.0 Hdi 160 (2010) for a few days. I've just noticed, under the bonnet, something odd.
On the left hand side, between the washer bottle and the coolant tank, is the tank holding the suspension fluid. Out of the rear of this tank, heading towards the bulkhead, there is a ~3" long hose that is just stopped off with a bolt stuffed inside, jubileed. What is this pipe supposed to do? Is the fact that it's been blocked off a pointer to a problem that has been 'cured'?
BTW, I gather that people know this model as an X7? Is that right? (2010 C5 excl.).
C5 X7 - hope this is not pointing to a problem
- My Cars: 2019 C5 Aircross 2litre diesel, auto.
2018 C4 Pic2 Spacetourer auto. Seems nice so far.
2019 C4 Cactus manual. Didn't like it, lots of niggling points. sold.
2011 C4 Picasso excl. - shaping up to be a disaster, bought June 2019. P/X'd
2009 Citroen C5 X7 exclusive, auto, LHD, 207500km (129000miles) now sold
Citroen Xsara Picasso excl. 2004 2.0 Hdi, RHD, 64000miles. (sold)
Citroen C3 Picasso excl. 2016. sold.
Two Xantias, one petrol, one diesel. sold.
In the past: Renault 16 (in about 1977, for a year). With front pass. seat out transported full bathroom suite from Cambridge to Derby!)
Renault 4TL (in 2011, for a year) - x 9
Re: C5 X7 - hope this is not pointing to a problem
At a guess, the tank has been replaced with one intended for a different model. Am I right in thinking that there was a batch of split, leaky tanks around that time? As long as the hydraulics work OK , I doubt that it's a problem.
- mooseshaver
- My Cars:
Mine has that too. No idea what it's for.
C5 III Tourer 2.0 HDi 163 Auto Exclusive
Gone cars.
C5 2.2 HDi Exclusive Estate auto 57. Awesome car. Sadly Could not be fixed by Citroen.
C5 1.6 HDi VTR Estate 56. Traded in.
C5 2.2 HDi SX Estate 02. Drowned in the floods of 09.
C3 1.4 HDi 92 SX 52.
Saxo 1.1 East Coast.
Gone cars.
If it's original, it's very odd that the pipe is stopped with a bolt.
As provision for some alternative arrangement I can believe, but surely there would be a 'proper' cap on it?
I'm sticking with a possible replacement tank; perhaps there were no direct replacements available due to the splitting problem, and this was the recommended dealer stopgap provision.
Thanks for the re-assuring replies.
- My Cars: Two C5's...
Lots of CXs...
A couple of Xantia...
A C2...
Lots of Prelude's...
And a Sunny! - x 66
- Contact:
Shockingly gash solution, if that is indeed the 'official' recommended fix!
Iain
1x '85 CX GTi Turbo s1 (metallic blue)
2x '85 CX GTi Turbo s2 t1 (metallic silver & grey)
'88 CX GTi Turbo s2 T2 (metallic light blue)
CX DTR T2 Safari (silver)
2x '96 Xantia Activa (Black & metallic green)
Iain
- Stickyfinger
- My Cars: Xantia V6 ACTIVA 3ltr 24v Manual p1
Xm 2.1TD Ph2 Exclusive
AX, little Daffodil
SAXO White Mk1. Sally - x 1297
- Contact:
Built like a German car
wurlycorner wrote:Shockingly gash solution, if that is indeed the 'official' recommended fix!
Activa, the Moose Rider
3x C5x7 Steering racks and counting
- qprdude
- My Cars: Renault 5 TS, Renault 14ts, Citroen C5 Mk1, Renault Clio sport, Renault Laguna Privilege. Citroen C5 X7 Exclusive. Citroen DS5 D/sport . And around 25+ other brands from Morris Oxford to S Type jag and most things between.
- x 10
Shouldn't worry about it. If the suspension is working and there are no leaks ,what's to worry about.
Plugging hoses with a bolt has been happening since the days of the "sit up and beg" Ford Prefect. It's probably as efficient as a fancy and expensive specialist cap or plug, and easily fitted or removed.
Rick.
2013 Citroen DS 5 D/Sport
Lots of CXs...
A C2...
And a Sunny! - x 66
- Contact:
Yes, my point though was that it's not what you would/should expect from a manufacturer as a designed solution.
Iain
Iain
- qprdude
- x 10
Can't see where it say's anywhere on this thread that it was in any way an official manufacturer designed solution.
Rick.
Lots of CXs...
A C2...
And a Sunny! - x 66
- Contact:
No you're right, that hasn't been confirmed, but it was noted that this has been seen on several C5's and it was suggested that was the recommended dealer fix. Which is why my comment said "Shockingly gash solution, if that is indeed the 'official' recommended fix!"
I'm not sure what the issue is here...
Iain
Iain
- qprdude
- x 10
.dnsey wrote:If it's original, it's very odd that the pipe is stopped with a bolt.
No problem. I just thought you might have misread the above post.
Rick.
