Am I sad?
jeremy
Kowalski
fastandfurryous
- x 4
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by FrenchLeave</i>
back in the days of piston engined aircraft it was de rigeur to coat the threads with graphite grease when doing a plug change.
Back in the days? 99.9% of light aircraft are powered by piston engines! There isn't really an alternative. It's not until you get up to 8 seaters and above that turbine engines take over.
FrenchLeave
tomsheppard
Fastandfurryous: This is twaddle, I'm afraid. with the sole failure of a master cylinder in the three Kas we have had in the family, reliability over 120,000 miles has been total.
No trim has fallen off, the aircon is very powerful, 42MPG is an average and nothing, nothing falls off. I have changed plugs at 30,000 mile intervals and never broken a plug, either. Taper fit plugs don't need drilling out of heads,just a little penetrant, when gently warm, then a ten minute wait before using a well fitting plug spanner, as we have been doing for more than 25 years. Only Ford servicing stopped me from buying another Ka. As you have said, it is heavy which is why the endura engine is used for low down torque. Being heavy, it is a better place to be than a Citroen in the event of a crash.
Skull
- (Donor 2026)
- x 369
Re: Am I sad?
ItDontGo Any updates on your AX experience ?
Did you keep it long ? ....Have to agree with the majority on here AX was a great car my favourite was the 1.4D 3 door I ran for 5 years bit noisy yes but good budget motoring ....fancy another as majority of my mileage is around town ...also agree about the accident / crash protection .... I glanced off the back of a Transit @ 30 mph which had pulled across a T junction on me and then stopped as there was no gap on the other side ....I hit the horn instead of the brakes and the front literally dismantled itself in the road
There wasn't a mark on the Transit
RIP AX
Ideally looking for a 1.4 TDi
Has anyone done a conversion to a TDi
RIP AX
Gary
Gary
van ordinaire
- (Donor 2017)
- x 402
Re: Am I sad?
You should only get rid of any car if:-
replacing it is cheaper than fixing it
you don't love it any more
you actually find something you like better (& can't have that as well!)
any combination of any two - or all three!
Citroens:-
'81 2CV Club
'05 C15
'97 Xantia Exclusive estate
others:-
Jeep XJ Cherokees x 3
'96 Cadillac Eldorado
'99 Cadillac STS
'81 2CV Club
'05 C15
others:-
'99 Cadillac STS
Skull
- (Donor 2026)
- x 369
Re: Am I sad?
Very similar to partners that van ordinaire ....
Opps .... coming Dearest
Gary
Gary
qprdude
- x 14
Re: Am I sad?
Was thinking of buying an AX and fitting a rotating blade underneath to use as a lawnmower.
Drive it to the dump and get yourself a babe magnet.
DS3 should do you.
Personally, the DS5 would be my choice but I don't need a babe magnet!
It's all about money really. If you value the low running costs of the AX then maybe you wouldn't appreciate a more modern and expensive car.
I suggest you leave the AX at home though, if you go out on the pull.
DS3 should do you.
Rick.
2013 Citroen DS 5 D/Sport
Skull
- (Donor 2026)
- x 369
Re: Am I sad?
I've pulled in the AX
Mostly the wheel trims
Love the DS5 as well but with only my local mileage my needs for a modern car are unnecessary
Gary
Gary
daviemck2006
- x 496
Re: Am I sad?
Get a Peugeot 205 for a babe magnet. Preferably a GTI, if you want to be really cool, but a 1.1 gl will do lol
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
Peugeot boxer 2016
In the family
wurlycorner
- x 272
Re: Am I sad?
Iain
CX DTR T2 Safari (silver)
Iain
Skull
- (Donor 2026)
- x 369
Re: Am I sad?
Gary
Gary
- x 1978
Re: Am I sad?
Ever been inside a DS5....with that very stupid design , a WALL they call a console ! You have NO CHANCE of even "copping a feel"
Dreadful interior if you 6ft.4in with legs
Skull
- (Donor 2026)
- x 369
Re: Am I sad?
I'm only 5' 8" though and felt cocooned in all those gadgets and leather .... as for coping a feel ....the salesman wasn't my type
Gary
Gary
