C5 X7 not starting (again)
- x 5671
Re: C5 X7 not starting (again)
Wasn't previously aware she was an actor.
- x 2000
Stepford Wife, from the original filmmyglaren wrote:Wasn't previously aware she was an actor.
qprdude
- x 14
If this goes any further, I'll be the only thing getting deleted.
Rick.
2013 Citroen DS 5 D/Sport
- x 5671
Wow, wasn't aware she was that old. Saw the film but didn't know who she was then and thought she was just a singer.Stickyfinger wrote:Stepford Wife, from the original filmmyglaren wrote:Wasn't previously aware she was an actor.
qprdude
- x 14
Spoke to the boss at the Citroen garage today and he agreed that it was going to be difficult to pinpoint the problem if it was starting OK when they got it in the garage. It could be expensive changing stuff for no reason. He also agreed with Dickie G in that a lot of faults are spurious and are thrown up for various reasons, sometimes for a split second, but they are logged so they appear. They fan one did come back though, but the guy said it would be unlikely to cause a starting problem. He also said the ECU does not have a cooling fan so it must be the engine cooling fan, or the A/C.
It seems like I'm going to have to wait until the fault reoccurs, then call the warranty people. Problem is, they will send the AA, who's main job is to get you going. What I need is, to have the non-starting car recovered to the Citroen garage.
Just my luck that the problem would go away as the car was being recovered!
Rick.
- x 2000
Can you not borrow a Lexia for a week, then plug it in before starting if it fails, that way you can save to report and view the fault.....tis the only way I can see to find the problem without luck.
DickieG
- Monaco's youngest playboy
- x 38
The problem being is that the car evidently isn't recording a code so unless you're familiar with all the readings on Lexia/Diagbox it's unlikely you'd be able to pick out what is wrong.Stickyfinger wrote:Can you not borrow a Lexia for a week, then plug it in before starting if it fails, that way you can save to report and view the fault.....tis the only way I can see to find the problem without luck.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
- x 3306
Unless, that is, it was one of the ones that were initially there, and that then cleared when told to do so. OK, I should have looked deeper into all of them, but I wanted to see what (if any) would come back.DickieG wrote:The problem being is that the car evidently isn't recording a code so unless you're familiar with all the readings on Lexia/Diagbox it's unlikely you'd be able to pick out what is wrong.Stickyfinger wrote:Can you not borrow a Lexia for a week, then plug it in before starting if it fails, that way you can save to report and view the fault.....tis the only way I can see to find the problem without luck.
DickieG
- x 38
Personally the way I'd go with this is to do another diagnostic session a few hundred miles and a week or so after the first reading and see what's there but I wouldn't bother worrying about the fan code, as I reckon that's spurious.
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
qprdude
- x 14
I think I've done about 5 miles since Hellrazor had the Diag-box hooked up last Wednesday. That's about my average unless I'm going to Aberdeen.
Rick.
