A collection of interesting/awful campers & motorhomes
Here's a starter for 10, bonus points if you can identify the base vehicle!
regards Neil
Re: A collection of interesting/awful campers & motorhomes
and just to keep it going
regards Neil
this is an interior view of a conversion of one of japan's finest :)
Does it look better from the outside?
regards Neil
x 3296
That last one looks like something is trying to mate with a Prius! Even the campers made by Top Gear looked better than that!
Conversion by Foley
regards Neil
electronmirror
x 30
Unread post by electronmirror »
The second one has Marina door handles but.......went to save the pic to desktop for a closer look and it automatically came up with the name 'Marina'... :-D
Ted
2010 C5 2.0 diesel(163) Exclusive Tourer (135,980miles)
1999 Xantia Exclusive Estate 110 Hdi Mauritius Blue with self peeling lacquer finish (276,174miles)
1991 XM Prestige 2.0 Auto(157,000 miles) gone but not forgotten
here's a marmite one
regards Neil
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
NewcastleFalcon wrote:Here's a starter for 10, bonus points if you can identify the base vehicle!
regards Neil
I do believe that it based upon a Cortina, is it called a Sandpiper or similar? I do recall it being basically a kit car from the days when I built my Cobra.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
Spot on.....definitely a Cortina, and very probably a Spartan Starcraft Camper.
Built by Spartan Cars, who are better known for their MG TD looking kit cars, it was offered either built or as a kit. The base car was the Ford Cortina which provided the entire front end (although custom bonnet and grills were available) including the engine and gearbox. This was mounted onto an extended custom dual axle chassis for the rear.
regards Neil
electronmirror wrote:The second one has Marina door handles but.......went to save the pic to desktop for a closer look and it automatically came up with the name 'Marina'... :-D
I reserve my best skullduggery concealing source refs from the images for the "Whatsthithen? thread.
If you picked out the Marina door-handles you should have no trouble with this rear-end :)
MikeT
x 232
Unread post by MikeT »
regards Neil
Mk4/5 Cortina-based Starcraft
Absolutely right Mike-According to the advert above they also did a kit for the mkIII, has the kit car camper conversion market collapsed now?
If you know your Fords this will be easy. I like a brown car in a so bad its good sort of way :)
regards Neil
One of Germany's finest innovations?
HEKU-Car-Camp
Successful proportions harmonize with a consistently applied aerodynamics, so that no air traffic jam entstehnt and the fuel is low. You drive a normal car and have but a motorhome. By coupling a residential unit to a standard Opel Astra, a recreational vehicle a new dimension created.
regards Neil
The morris minor has not been immune to the campervan convertors
regards Neil
MikeT
x 232
NewcastleFalcon wrote:Absolutely right Mike-According to the advert above they also did a kit for the mkIII, has the kit car camper conversion market collapsed now?
regards Neil
Zodiac can't recall the mark though. I used to have the model before (as seen in Z-cars)
