Peugeot 206 2.0 HDI won't start HELP PLEASE
sheeny1994
New User
Unread post by sheeny1994 »
I have just acquired a 2000 reg 206 HDI from a friend as it had become surplus to his requirements and has issues.
The car has been stood for 2 years. Not started no battery nothing. I went to collect the car and it is refusing to start so stuck it on a tailor and brought it home.
So far my findings are that it will not pump fuel on its own. The only way to get it to pump fuel is to attach a battery directly to the fuel pump. However although this solves the fuel issue temporarily the car still refuses to start?
Also there is no coil light when turning the ignition on which according to my mate who had the car always used to come in for a few seconds before starting
Any help greatly appreciated
Sent from my iPhone using Tapatalk
x 3296
Re: Peugeot 206 2.0 HDI won't start HELP PLEASE
The coil light is for the glow plugs, and only normally comes on (for a few moments) when the weather is very cold.
There are any number of reasons as to why this is happening, and chasing round the houses won't work. Check the following link for forum members who have Lexia systems, and are willing to help;
http://www.frenchcarforum.co.uk/forum/v ... 19&t=29178" onclick="window.open(this.href);return false;
Just a thought. When you turn the key (not to start her, just to get the dashboard lights on) is there a light that looks like a key in a square that stays on. If it comes on for a moment and then goes out, great (it means the immobiliser is working, and has accepted the key as legitimate). However, if it stays on it means the immobiliser isn't convinced the key is real (and won't allow the engine to start through various means).
Oh, welcome to the forum, by the way! :welc:
sheeny1994
New User
Thanks for your advice, much appreciated
Managed to get it started last night turned out to be 1 fuse causing the issues. Crazy how 1 little part can make such an impact :)
x 3296
Well done. If the fuse was linked to the immobiliser system then it would do that.
x 1056
Unread post by wheeler »
If the key is not recognised on this system is doesn't inhibit the fuel pump though, it just locks the injection ECU & stops the injectors firing.
