Xantia Keypad
x 1998
Re: Xantia Keypad
Unread post by Stickyfinger »
Can you not just take it out of gear and haul it on as you are scrapping it ? even use the starter to assist the pushers
x 1472
Re: Xantia Keypad
Unread post by xantia_v6 »
rossnunn wrote:This is looking like a dead duck then. Oh joy.
Does the immobiliser kill the spark or just the fueling?
Both.
Is it a car that is otherwise worth saving?
rossnunn
Re: Xantia Keypad
Unread post by rossnunn »
Bugger.
The only real reason to starting would be to aid loading. The only trailer we have ha quite a high bed & shortish ramps so the threshold where the ramps meet the trailer deck is quite pronounced. We've had 'normal' height cars bottom out - so heaven knows what the Xantia will be like - looks like we are going to have to get 'creative' with it.
Can the code be read from the ECU with a diagnostic tool such Snap-On Solus unit or simiar or is it a dealer only job?
x 1998
Re: Xantia Keypad
Get the scrapper to pick it up and save the trouble ?
x 1472
Re: Xantia Keypad
rossnunn wrote:Bugger.
No the code cannot be read with any normal diagnostic tool.
I have seen reference to dead Xantia being raised by taking off the aux belt and spinning the pump with an electric drill (connected to the pump pulley with a suitable belt and pulley)
rossnunn
Re: Xantia Keypad
Xantia v6 - now that's not a bad idea......
wurlycorner
x 271
Re: Xantia Keypad
Unread post by wurlycorner »
Sounds like take the plugs out, crank the engine over with the starter to get the suspension pumped up and then winch/pull/push job then.
Iain
CX DTR T2 Safari (silver)
x 695
Re: Xantia Keypad
Unread post by Mandrake »
RichardW wrote: But... if you look at the keypad at an acute angle in bright light, you might be able see a build up of finger grease around the 4 keys that make up the code. This may give you a clue what the code is (phone number, birthdays etc), or reduce the number of combinations you need to try to 4^4 (256) :lol:
And with a 30 minute lockout for every 3 wrong attempts, it would only take you 43 hours of continuous attempts to try all combinations. :rofl2:
wurlycorner
x 271
Re: Xantia Keypad
:rofl2:
Iain
