Strut Tops....what Preventive maintainace can be done ?
x 1995
Unread post by Stickyfinger »
Header says it all....Strut Tops....what Preventive maintainace can be done ?
( part of my OCD sorry )
elma
x 287
Re: Strut Tops....what Preventive maintainace can be done ?
Unread post by elma »
I waxoil them before fitting them. Other than that regular car cleaning and keep the boots on. They seem to last a decade if not lookedcafter so should be alright with some care.
x 94
Unread post by citronut »
wax oil will degrade the rubber coating/bonding, once this has degraded the weather will get into it and agitate the tin worm
Regards, malcolm.
x 1995
this ? looks like it is designed for an aggressive environment :)
http://www.rib-shop.com/rib-revive-rib-cleaner/
x 94
Stickyfinger wrote:this ? looks like it is designed for an aggressive environment :)
isn't that just a cleaner Mr Sticky????
i would have thought the likes of a
http://www.toolstation.com/shop/p21983? ... tAod6yUARg" onclick="window.open(this.href);return false;
might do the job
Regards, malcolm.
x 1995
I would not use silicon on rubber, it leaches out the oils and allows it to develop surface cracks by allowing ozone to attack it.
That above is part of a range, a cleaner and a "protective spray"..as it is used for boats, and has good reviews, just wondered. ??
http://www.rib-shop.com/rib-conditioner/
Even on the C6..which means some X7's will go soon :)
