Anybody near Exeter?
x 94
Re: Anybody near Exeter?
Unread post by citronut »
DHallworth wrote: Image
David.
here'z my response to the Haggis lobbing device :kiss: :yikes: :-D :lol: :rofl2: :rofl2: :wink: in the picy above over on club XM
http://www.club-xm.co.uk/forum/viewtopi ... 0&start=10" onclick="window.open(this.href);return false;
Regards, malcolm.
DHallworth
x 162
Unread post by DHallworth »
Well, the sphere charger has landed... It's a great tool and everything is there :D
It's got the complete trolley that the gas bottle sits on...
The sphere screws into the side of the trolley so that it's secured whilst your regassing it...
There's a pipe that runs from the socket that the sphere is mounted into and runs into a bottle to collect the LHM...
The gauges are complete, one of the gauges shows the pressure left in the gas bottle and the other shows the pressure in the sphere...
The valve goes into the tool as below and is screwed onto it...
The genuine Citroen valves are identical to the tecnosir ones that you can still buy... :D
However... The best bit is the original genuine Citroen instructions are with it...
The 3rd page shows the pressures for a couple of models of sphere...
The 4th page shows the insturctions for using the charger...
I've got a masssive pile of spheres here that I need to sort out, I'll work out which ones I've got that are genuine Citroen ones and bin the rest.
David.
'98 Xantia Activa V6 :-D
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
x 5683
That's magnificent David.
You will have hours of fun with that :)
superloopy
x 19
Unread post by superloopy »
Had it got the tool for loosening existing endcaps?
Mike
DHallworth
x 162
Thanks Steve! I should have shown you it on Sunday if I'd thought about it as it was hidden behind the tents!
It hasn't got the tool for loosening the end caps, I've done that before with a pair of stilsons though :)
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
