Xantia - LHM leak front wheel arch
Jaf
x 42
Unread post by Jaf »
Hi folks. Just been checking Fred's front brake pads. Found horrid LHM leak. It's a rubber to metal pipe on the side of the shock absorber. The splatter has gone all over the wheel arch, wheel, cv.
Can't work out how to post pics from iPad but will try desktop if pics help.
Anyone know what the pipe is please and any advice greatly appreciated. Thought I'd seen the last of the leaks with the brake doseur. Sigh.
Thank you.
Fred, a silver 1998 1.9TD SX Xantia.
Gwin, a white 1994 1.1 AX.
les
Locked user account
Re: Xantia - LHM leak front wheel arch
Unread post by les »
Sounds like Fred's fluid return pipe has split.Still available from main dealers,simple job,the clamp on the strut can be a little tricky without the proper tool.I used carpenters pincers with succsess
Jaf
x 42
OK thanks! Don't suppose you'd remember the part number? (Crosses fingers)
superloopy
x 19
Unread post by superloopy »
Common across a few cars XM, Xantia, C5.
95050399 - LEAK BACK HOSE - £16.37 inc vat.
There are a few to be had on 'Bay ... at or around that price :)
Mike
Jaf
x 42
Thanks! Just cleaned her up a little and can see the split.
x 1971
Unread post by Stickyfinger »
If it is at the joint often they can be trimmed back a little (as long as it stays "passive" with no strain on it)
x 94
Unread post by citronut »
here is price and part No.'s for the strut return and its clip from citroen
95050399 LEAK BACK HOSE 13.64 GBP 16.37 GBP 16.37 GBP
96127591 ADJUST COLLAR 4.61 GBP 5.53 GBP 5.53 GBP
Regards, malcolm.
Jaf
x 42
Thanks. Have ordered the bits. Going to change both sides just in case.
Jaf
x 42
Well finally got 1 pipe and 1 clip. Citroen gave me €1.50 off as there should be 2. Don't know how they balance the books! Hope to get the pipe for other side next week.
Anyway...pipe fitted. Lovely to have an easy job.
