x 1999
Re: shortly to become an Activa owner...Project Stictiva
Unread post by Stickyfinger »
As per ?....I would round off the corners however to prevent any stress fractures forming and the loads to flow
Looking at it I would also like to keep inside the flat area and not extend into the pressed edges.....is that correct for max strength ?
Skull
(Donor 2026)
x 378
Unread post by Skull »
A or B for me ....but made out of perspex so we can see the flux-capacitor working 8-)
Gary
x 8360
Ahh :!: Just spotted the Angel Grinder!!!!
x 1999
Final shape
one way of stopping LHM on next doors gravel :)
Northern_Mike
I actually quite like the entire thing cut out! Easy access to all the suspension bits. Make a nice access panel to go over that, plenty of bolts and I bet it wouldn't affect stiffness that much. The Xantia isn't the stiffest car in the world anyway so I doubt it'd be even noticed.
Sent from my SM-N9005 using Tapatalk
x 8360
Stickyfinger wrote: one way of stopping LHM on next doors gravel :)
I like... A lot! :-D
x 1999
Should I send an application to Bogit Bogit & Legit ?
x 8360
It's far too good for that :wink:
x 1999
x 8360
That might do Sticky but do check LHM resistance first.
Get hold of one, drop it into a jar full of LHM and leave it for at least a week to see if anything happens to it such as hardening or softening.
wurlycorner
x 271
Unread post by wurlycorner »
:roll: the plumbing is even worse back there than I had thought. Definitely engineered by someone that had the sub frame in front of them, but not the shell :lol: (or just didn't give a flying ...)
Iain
CX DTR T2 Safari (silver)
x 1999
wurlycorner wrote::roll: the plumbing is even worse back there than I had thought. Definitely engineered by someone that had the sub frame in front of them, but not the shell :lol: (or just didn't give a flying ...)
You can get to a fair bit from under if you take off the spheres, this will allow you to avoid stripping down and dropping the frame to get to the ram hoses and the leak off connector mainly....so to me well worth doing
Max area
Template
Cut Out
x 1999
FINISHED, Fixed and NOT leaking............FFS Citroen !
Anti corrosion wax applied....good protection for Aluminum as well apparently but designed for truck electrical connectors.
x 8360
Good work Sticky [-o< Excellent :-D
Can you now please make a full template available do we know where to cut when it comes time to do ours?
x 1999
CitroJim wrote:Good work Sticky [-o< Excellent :-D
Will do
The Activa has taken its toll on me, ripped my back BAD getting into the boot and twisting to get access with the dremmel....OUCH ya bugger
