x 1989
Re: shortly to become an Activa owner...Project Stictiva
Unread post by Stickyfinger »
then after a few years = poor residuals =- more small sales = aww feck (in French)
x 8325
Eating in a particularly good French restaurant last evening we counted a very healthy number of Xantias, albeit quite battle scarred, running around Paris....
Of all the older Citroen we saw, by far the most numerous....
x 1989
Top visit then :)......one thing I noticed on my trip South the other week was how few C5's there were, esp the X7, just did not see many.
A boot full of Cheeeeeese and Wine (and a glove box of rare parts from the museum) :)
x 1989
Just trying for size at the moment...One Dips (shutter) the other is a high beam.
Skull
(Donor 2026)
x 375
Unread post by Skull »
Cool 8-)
Gary
x 1989
As fitted to a S1 light box, they fit even easier, and will need only minor mods to get them 100% stable.
x 8325
That is neat :-D =D>
x 1989
Cheers on the lights guys...its a fiddle with something late at night job !.............. :)
Update on my leaking Activa Ram....
Top joint off and ram dropped free, bellows gaiter off (see the damage).
The top seal, as Jim said is the cause of the fluid loss and thankfully the ram is not damaged.
I will also Need a Lower Ram bush, anyone know the size as I have to get one made I think......
x 1989
Cleaned up ready for working on the area.
?? Does the base of the metal sleeve (its flaired skirt) fit into a grove formed into the leak-off ring to form a seal ?? ?
x 8325
Stickyfinger wrote: ?? Does the base of the metal sleeve (its flaired skirt) fit into a grove formed into the leak-off ring to form a seal ?? ?
Nope, just sits on top of it in a cone..
Another reason for it leaking...
x 1989
Any reason why an Adhesive(*)seal with a suitable mastic could not be used/made or does it need to decompress the void when the ram compresses by venting.
It seems to me that there would be compression of the air within the sleeve as the Ram contracts if the sleeve is sealed at the skirt, how does that inner void normally vent/equalise
EDIT:....There IS a pressure vent hole in the Gaiter,
x 1989
Lower Ram Bush......awwwwww bugger
Bad day !
x 8325
Poor dog... He's obviously missing the fruit of your chickens - like me!
See my website - tells you all you need to know on the subject :wink:
x 1989
working on your own holding a £600 part connected by old hoses.....pita !
x 8325
Those hoses are very tough Sticky...
