Xantia front strut leakage returns
Dommo
x 20
Unread post by Dommo »
Hi all
Apologies if there is a thread on this somewhere, I did look but couldn't see anything obvious beyond the usual hose replacement.
My query is regarding to the rubber part that is clipped to the strut, that the hose comes out of. Today while replacing a wheel bearing, bottom ball joint, drop link and track rod end (all to try cure a new grumble and a long-standing clonk) I noticed that the leakage return hoses were cracked, so I followed the hoses around to where they mount into the struts and noticed that the rubber on the struts look awfully perished.
Are these rubbers replaceable or do you need new struts??
Thanks very much. Dom.
x 1481
Re: Xantia front strut leakage returns
Unread post by xantia_v6 »
The rubber block comes attached to the new hose, they are one piece.
x 1240
Unread post by Peter.N. »
They also come with a metal securing clip which I have never had any success with so I use a couple of cable ties.
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
I didnt have scucess with the clip untill i got the proper pair of clip pliers to do them.. now all the cpipped hoses are reuseable now.. so handy having the peoper tool..
If your clever you can also remove the metal 0late from the clip and put it on a hose clamp with worm drive and hold it on that way.
A very sad...
1994 XM 2.1 d auto
x 94
Unread post by citronut »
here is price and part No. for the leg pipe and clip
95050399 LEAK BACK HOSE 13.64 GBP 16.37 GBP 16.37 GBP
96127591 ADJUST COLLAR 4.61 GBP 5.53 GBP 5.53 GBP
citroenxm wrote: If your clever you can also remove the metal 0late from the clip and put it on a hose clamp with worm drive and hold it on that way.
sorry to pooooo pooooo yoour suggestion Sir Paul,
but i think if Joe public use a jubilee clip to secure the rubber block of the leg pipe, they will more than likely over tighten it to the point the edges of thew block curl outwards and leak, even using the metal plate from the original clip
Regards, malcolm.
citroenxm
Fallen Hero
x 70
Well poo poo to you to malc.. i did say ".. if your clever. ." .. but yes watch for over tightness. . Ive done it myself..
Its early i ommitted that because i didnt even think about it at this early hour..
A very sad...
1994 XM 2.1 d auto
x 94
ok hun i'll let you off this time :twisted: :shock: :roll: :yikes: :wiggle: :wiggle: :eye: :eye: :teabag: :teabag: :-D :lol: :rofl2: :rofl2: :wink:
Regards, malcolm.
Dommo
x 20
Thanks for the replies guys that's great. I have ordered the leakage returns from Citroen, should be in by Wednesday hopefully. Here's hoping they don't leak before then - sods law and all that!
Out of interest citroenxm, what do the proper clip pliers look like so I can source some?
Cheers.
citroenxm
Fallen Hero
x 70
Ask me again next week when im home to take a pic.. let me see if i can find an add for some.
A very sad...
1994 XM 2.1 d auto
x 1499
Loads on Ebay
citroenxm
Fallen Hero
x 70
Those are mine sort...
A very sad...
1994 XM 2.1 d auto
Dommo
x 20
They do look similar to the tool we have, ours differ in that both jaws have the cut out in them, and they don't open as much as those ones. I think they're a pair of cutters to remove the insulation from around a cable, but they seem to work for the type of clips that hold the LHM pipes to the tank.
It would probably be worth me getting some proper ones for the job...
Cheers
