....nope....big and mostly round but with no rubber attachedSkull wrote:Stickyfinger Can you spot what is missing ?.
Bleed nipple & Dust Capand a wheel and tyre
- x 1982
Re: shortly to become an Activa owner...Project Stictiva
Skull
- (Donor 2026)
- x 370
Spare wheel carrier
Gary
Gary
- x 1982
nope, that is still attached...
brake dust/rear Guard....not fitted
Skull
- (Donor 2026)
- x 370
Looking nice though
Gary
Gary
- x 1982
I especially don't like exposed aluminum when there is any chance of salt about, hence the paint (with etch primer under) or a wax coating/white grease.
Any stone chips are easy to spot once cleaned a bit, a quick wire brushing is all it takes so far, so apply rust treatment, chassis black, stone-chip ...... very happy with the condition of the undersides so far.
- x 1982
IT's ALIVE !.............then dead....then ALIVE again !
Off ramps this afternoon, new brakes are wonderful, no water leaks, dry squeaks gone...then HISSSSSS.....steam hisssss, aggg bugger !............ at the top of the hill happily, so turned it off and coasted home. One popped hose, outlet to swirl pot .rats
Another hose fitted after removing air box, one HOT HOT arm and hose re-attached.
Its ALIVE again, oh the Joy, oh the panic, oh the Joy....
Skull
- (Donor 2026)
- x 370
Close call ....don't kill it ....life is a roller-coaster
Gary
Gary
- x 1982
BLOG Update: http://stickyfinger-activa.blogspot.co.uk/
Had this
Found this to day....I wonder what I will find inside.
Not many more places to look
Had this
- x 8203
Is that the ram on the rusty TCT Sticky?
- x 1982
Nope, that's the one on the V6 Jim.
I have looked thru the gator and the piston feels/looks clean and unmarked (from what can be seen), I will take it all off today.
?? is there a way of taking off a Ram (from the rusty one) but then sealing the pipes to keep the car movable ?
I need to keep the Rusty-One as a mover ATM as it is stored with next door as a mobile garage door lock
- x 8203
Not really Sticky, it would be difficult as the ram forms a droplink. If you could make up a crude substitute link and link the hydraulic pipes together it might wok but that's as much work as sorting out the V6 ram,nice not more.
You can fix the V6 ram in-situ no worries. Follow the guidance in my blog....
- x 1982
Bonjour Mess Jim and the French invasion crew...
That is if I can get a gaiter?..... ?
wurlycorner
- x 272
Amen to that. Can't believe the things it's impossible to get for a Xantia these days...Stickyfinger wrote:Look at Cit Service...it will frighten you David ...now is the time to get a spares car and start looking at ebay for your shelf.
There was even something I checked for the C5 that was no longer available! I mean... WTF?
Absolutely crap. I can still get all sorts of even random bits of trim from Honda for my early 90's Preludes! PSA after care absolutely sucks these days.
Iain
CX DTR T2 Safari (silver)
Iain
- x 1982
A closer look
I cleaned....and just had to stop it dripping, running down a lip, and dripping onto the Activa ram bellows half way down and out of sight behind, well that added to the puddle I thought was 100% ram leak, but I wonder how much ?...
A bit more metal protecting to do before it has to suffer British summer weather, all will clean up well with a small headed long handled wire stove bush, I do not want a dry day car only, just one that sees zero salt so a good 3m undercoat will be fine with dinatrol sprayed around as well.
Northern_Mike
It always did. This is nothing new.wurlycorner wrote: Preludes! PSA after care absolutely sucks these days.
This is why there's so few old Citroens of any sort left. No parts = scrap car = another sale for Citroen..
Sent from my SM-N9005 using Tapatalk
