Had a play yesterday with Diagbox and came across the settings for adjusting ride height. Default settings 128 steps front and 120 rear (steps are approx. 1mm each). Found also the following in one of the service manuals.
If you enter a value outside the allowed range it revert to the default 128 front and 120 rear steps.
This is where it gets interesting.
If you enter 140mm at the front and 073mm at the rear you are not changing the height.
If you enter heights greater than 140mm at the front and 073 at the rear the vehicle LOWERS both front and rear. ie 145mm at front will LOWER front by approx. 5mm.
Haven't tested it yet but will try over the weekend.
C5 X7 Hydractive suspension settings
osx
- x 15
C5 X7 Exclusive 2.0 HDi Auto
vborovic
- Locked user account
- x 40
Re: C5 X7 Hydractive suspension settings
I never figured out what you're trying to do with the ride height, lower it permanently, or make it higher ... that the default?
OnlineStickyfinger
- x 1996
better just to put a BMW sticker on the boot
vborovic
- x 40
Be My Wife? If I recall, the guy got married not too long ago ...
Jodyone
- x 3
It's hella complicated- try this thread (on C6owners) for starters:
http://c6owners.org/plugins/forum/forum ... ?8035.post" onclick="window.open(this.href);return false;
2006 C6 Exclusive, 2.7 HDi - Big Ron. Long gone!!
osx
- x 15
Settings are different for the C5 but found a service guide with the measurements points for the C5. Easier compared to the C6Jodyone wrote:It's hella complicated- try this thread (on C6owners) for starters:
osx
- x 15
If you change wishbones you will have to do it this way if you don't want to spend all your time under the car adjusting the height sensors.vborovic wrote:I never figured out what you're trying to do with the ride height, lower it permanently, or make it higher ... that the default?
osx
- x 15
http://service.citroen.com/dtt/IFD/AC/d ... iag037.pdf is a better read
