clutch cable part number, 95 xantia 1.9td
elma
x 284
Unread post by elma »
Can anyone confirm if 96137579 is the correct part number for my clutch cable please? Its for the car in my signature. Also is it necessary to buy a clip with a metal spring or just a plain old clip?
x 1488
Re: clutch cable part number, 95 xantia 1.9td
Looks like the right one - post up the VIN and I'l check. NFP from Citroen.... You will need both parts of the clip - unclear if it's the plastic or metal that lets go first, but both usually end up broken. I'd be surprised if it's not been replaced before on a 95 car - but I'd replace it if you are going to the trouble of having the pedal out anyway! Have fun with it :twisted:
elma
x 284
Hi Richard, the rp num is 6811 (I think) and the VIN is VF7**************[VIN obfuscated, can be read by forum staff]
I don't think that it has been changed before, the bolt is in the oem way round and the cars 7 miles short of 110k.
x 1488
That's the right cable part number. Should be a manual adjust.
That picture is the RP number - although service.citroen thinks it was built the day before :-D
elma wrote:I don't think that it has been changed before
It's doing very well!
elma wrote: the bolt is in the oem way round
Double the fun then. Get a new bolt on hand (M8x1.25x70) in case you need to saw the head off!
elma
x 284
Thanks Richard, I'm ordering the bits now. Getting a nut and bolt too, can't be a bad idea. I'm not driving further than I'd walk home at the minute as I'm sure its going to snap soon.
