removing heater control panel
harryp
(Donor 2022)
x 73
Unread post by harryp »
Hi all, Gremlins strike again! Heater fan suddenly went onto full speed and stays there, engine running or not. Very noisy and irritating.
Read various posts and it seems to be a wiring problem. How do I remove the heater control panel? Dear old Haynes suggests removing the whole dash/facia which sounds a little extreme. Is there another way?
Xantia hdi 110 yr2000.
still no turbo....... :cry:
Regards
Regards, Harry
2000 Nov Forte HDI 110 hatch in Wicked Red; currently SORN
2000 Mar Exclusive HDI hatch in Quartz; currently SORN
2013 C4 Picasso Excl E
Peugeot 207cc 1.6 Roland Garros
x 1439
Re: removing heater control panel
Unread post by xantia_v6 »
It is most likely the motor control transistors which are mounted on the motor, NOT in the control panel. Search the forum for "transistors" for more information. Complete modules are available on Ebay and Amazon, but some are of inferior quality (to the point of being useless).
Northern_Mike
harryp wrote:Hi all, Gremlins strike again! Heater fan suddenly went onto full speed and stays there, engine running or not. Very noisy and irritating.
Regards
It'll be the resistor pack that's mounted on the fan blower unit itself, not the control panel. It's cheap and easy to replace. There's plenty of threads on here about it but I find searching for them on my phone hard work ;-) it's a job I've do e myself, twice, after I've had resistor packs repaired by someone better than I..
Sent from my SM-N9005 using Tapatalk
harryp
(Donor 2022)
x 73
Thanks guys :) . As soon as the hail and sleet stop will remove and check! Will let you know how I get on.
Regards
Regards, Harry
harryp
(Donor 2022)
x 73
All done :)
As was suggested, it was the transistors..... I changed over the one in my Exclusive and now it is working fine! Will now have to order transistors to effect a repair!
Thank you for all your responses - yet again.
Kind regards,
Regards, Harry
