ERm which bulb is it
Turn lights not onto full beam but so dash lights up etc
in the main lights at front one bulb is out.
Whats this called please
and easy to replace??
C5 Mk1 estate :-0
Bulb advice
ej2095
Bulb advice
C5 2.2 HDI Estate mk1 (With a anti theft fury dice device)
ej2095
Re: Bulb advice
when i turn on main beam both work but the one light is till out...
- x 5617
ej2095
Re: Bulb advice
Thats the one the sidelight...
am a complete car novice.
Whats the bulb called please. i.e what do i look for from eurocar parts etc? (Be buggered if am going to halfords)
qprdude
- x 14
Re: Bulb advice
Why not Halfords,they sell the same bulbs.
Rick.
2013 Citroen DS 5 D/Sport
ej2095
Re: Bulb advice
becuase they are robbing bar stools with there prices
- x 1240
Re: Bulb advice
Ebay then.
- x 2943
Re: Bulb advice
The bulb's a 12 volt 5 watt capless and you can get a box of ten for just over a quid http://www.ebay.co.uk/itm/10-PACK-501-S ... 3f3179f43a
SaabC5
Re: Bulb advice
501 bulb, dead easy to replace on the MKI. Take headlamp cover off rear of lamp unit by turning 90 degrees, pull sidelight bulb holder out and push fit the replacement bulb, push into sidelight hole and re-install headlamp cover. You can use LED bulbs for brighter sidelights but bear in mind they will only fit one way in the holder because they are polarity specific, standard 501 bulbs will work either way around.
09 C5 X7 2.0Hdi Exclusive in Perla Nera black (the best colour)
ej2095
Re: Bulb advice
these teh same type of bulbs that light up the dash light where its says "autoamtic windows wiping" etc?
Asking as i replaced the bulbs in there couple o years ago and had a shed load left
chinkostu
- x 30
Re: Bulb advice
Theyre abiut the size of a fingernail on your little finger.
Think the dashbulbs are the tiny ones
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto
1996 306 1.8 XN Auto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
