1.9td questions
xsaras4ever
x 44
Re: 1.9td questions
Unread post by xsaras4ever »
Thanks for that CitroJim.
Now getting closer to installing replacement engine.
Out of curiosity we removed the head on the original.
When we popped it off we thought - Wow - the pistons looked clean.
Ran a finger across them - wet with a thin film of oil.
All 4.
Strange.
Very unlikely to have a ring problem on all 4 pistons.
Very unlikely to have valve stem oil-seals bad on all 4.
Surely it has to be coming through the intake manifold ?
Jumper 2.5d
406 Phase 2 Estate, Hdi
Fiat 500 (2009)
1997 Audi A3 tdi
Peugeot 205 td
Fordson Major Tractor
Nuffield 460 tractor
JCB 3cx
Fordson Super Dexta
Massey Ferguson 65
x 8378
Re: 1.9td questions
The oil may have come via the crankcase breather system... This is the normal reason for oil condensate being present in the inlet tract and often gathers in the intercoooler...
This is quite normal...
xsaras4ever
x 44
Re: 1.9td questions
Hello CitroJim and thanks again.
However we are not so sure - from experience but possibly from lack of knowledge. #-o
Any engine we have ever taken apart has been fairly dry - yes black shiny pistons sometimes but not much. More often quite dry black carbon.
The air intakes will be damp with oil but generally the heat in the combustion chamber keeps the piston and bore a little more dry.
You could scrape the oil/grease off these pistons with your finger-nail - we have never encountered that.
Admittedly we cannot remember when we last took the head off a turbo engine so not much (maybe none) experience there.
Anyway, progressing slowly - gearbox bolted to engine last night - manifolds and turbo tonight.
Its been a slow one this - and that gearbox weighs a ton.
Jumper 2.5d
Fiat 500 (2009)
1997 Audi A3 tdi
Peugeot 205 td
JCB 3cx
Fordson Super Dexta
Massey Ferguson 65
xsaras4ever
x 44
Re: 1.9td questions
Engine and gearbox finally prepared to go IN
After taking van out of garage and powerwashing engine bay -- no --- don't think they will allow us on the road like this -- discover that IN is not ready to engine.
Rot in both front inner wings - under battery tray and under air filter - time to get the welder out
Jumper 2.5d
Fiat 500 (2009)
1997 Audi A3 tdi
Peugeot 205 td
JCB 3cx
Fordson Super Dexta
Massey Ferguson 65
x 8378
Re: 1.9td questions
Looking sweet!
xsaras4ever
x 44
Re: 1.9td questions
Thanks Jim, its been slow getting to this..
Jumper 2.5d
Fiat 500 (2009)
1997 Audi A3 tdi
Peugeot 205 td
JCB 3cx
Fordson Super Dexta
Massey Ferguson 65
xsaras4ever
x 44
Re: 1.9td questions
Hello again to all.
Engine bay welding completed and bay painted. Engine is in but not fully connected.
On the bodged wiring thing - been having a good look and the reason it wasn't immediately apparent is because there are 2 bodges.
1.) ignition to solenoids on injection pump - key symbol lit on dashboard. Standard bodge to by-pass immobiliser - though we cannot see a lexia port anywhere so that we could re-code keys.
2.) Pre-heater control box - removed completely.
It has been replaced by a relay and a switch on the dashboard. You pull the switch for 10 seconds and it activates the relay which fires current through it directly from the battery.
It works , its ugly, its stupidly clever in its own way.
We visited the scrappy and bought a box from a 1.9td xantia. The 5 pin connector fitted. We wired the input direct to the battery and the output to the plugs. Nothing.
Checked the fuses, no fuse present for the pre-heater - worrying.
Fitted a fuse , it worked - but the preheater box didn't stop delivering current when the ignition was on , ever.
The fuse smoked and melted - but didn't blow - weird.
Would like to return it to original - any suggestions from a more electrically minded person than us ?
Thanks to all once again.
Jumper 2.5d
Fiat 500 (2009)
1997 Audi A3 tdi
Peugeot 205 td
JCB 3cx
Fordson Super Dexta
Massey Ferguson 65
x 94
Re: 1.9td questions
Unread post by citronut »
sound like you have connected the wrong wire directly to the battery??????,
Regards, malcolm.
xsaras4ever
x 44
Re: 1.9td questions
No , dont think so. Wired it as it was in the Xantia. Side with big brown in-line fuses to battery (10mm on box)
Smaller side (8mm) to plugs.
You would expect the fuse to blow before the plastic casing of the fuse melted , scary that.
Also , no glow-plug symbol on dashboard, although dont really know if the boxer had one- but would expect it surely had.
Jumper 2.5d
Fiat 500 (2009)
1997 Audi A3 tdi
Peugeot 205 td
JCB 3cx
Fordson Super Dexta
Massey Ferguson 65
x 94
Re: 1.9td questions
if it were one of the inline after market blade type fuse holder,maybe it was not tight enough on either the fuse legs or the cable connections
Regards, malcolm.
xsaras4ever
x 44
Re: 1.9td questions
Yep , will look at loose fuses.
Almost there, most welding done and rads connected.
Filled up with water (antifreeze later when all is well) and it weeped out of the head gasket.
Our own fault as we didn't buy new bolts, and on the tightening we torqued them up and then from memory its 110deg + 110deg.
Our bolts sqeaked a lot (and we got very scared) so we did 90deg and then nothing.
Will order new bolts and fit them. Damn - another delay.
Jumper 2.5d
Fiat 500 (2009)
1997 Audi A3 tdi
Peugeot 205 td
JCB 3cx
Fordson Super Dexta
Massey Ferguson 65
lexi
x 134
Re: 1.9td questions
Unread post by lexi »
Always a good idea to run a bottoming tap down the head holes. If no tap then a head bolt with a slot cut down it can gather dirt and swarf for you.
Amazing what comes out.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Xantidote
x 5
Re: 1.9td questions
Unread post by Xantidote »
lexi wrote:Amazing what comes out.
A compressed air "gun" is good for blowing the cr*p out
Martin
x 94
Re: 1.9td questions
thats what i use
Regards, malcolm.
xsaras4ever
x 44
Re: 1.9td questions
Very Very bad day today.
Torqued head down yesterday. 60nm + 110deg + 110deg.
Cripes - no chance to overtorque this we thought - arms aching.
Put all back together today - filled with water - no leak at head-gasket.
Started engine - selected 1st gear - lifted clutch - nothing.
Selected any gear - nothing.
Slackened off clutch cable - nothing.
Disconnected clutch cable completely - nothing - no forward or reverse movement of van.
Crawled underneath for the umpteenth time - cable nicely operate gearbox - but no movement.
With van in any gear you wish we can push it - no gearbox being engaged with engine. Its a new clutch and pressure plate and release bearing but same old gearbox and linkage.
Very puzzled - only thoughts are that clutch cable was too tight and as its been sat in garage like that for at least a month the pressure-plate has seized in an open position - or its the wrong clutch - but we measured it. Absolutely puzzled and cheesed off.
But it gets worse.
It still smoked like hell and we had a blow at the exhaust where the turbo exit manifold joined the exhaust pipe.
We un-did the two bolts here and by co-incidence topped up the water - it ran out of the exhaust.
Checked the oil - now too much and grey - it was only 10 minutes old.
Cracked head for certain we think. All that work - new stem seals - regrinding valves - everything - all for nothing.
Jumper 2.5d
Fiat 500 (2009)
1997 Audi A3 tdi
Peugeot 205 td
JCB 3cx
Fordson Super Dexta
Massey Ferguson 65
