Disabling Xantia alarm?
x 8325
Re: Disabling Xantia alarm?
Mike, the alarm can be reset by holding down the ultrasonic disable (crossed - out speaker) button whilst turning on the ignition...
It only needs doing once but will need to be done every time the battery is disconnected and reconnected.
Totally forgotten now how to re synch an S1 pip :oops:
chinkostu
x 30
Unread post by chinkostu »
What jim said is true, i had to do the same even when I got the plip going as the alarm had a headfit. Apparantly the correct reset procedure is remove battery negative, refit and quickly turn ignition on when holding the alarm button down. The indicators should flash!
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto :oops:
1996 306 1.8 XN Auto :?
1996 Fiesta 1.3 #-o
chinkostu
x 30
Mine went nuts until i figured it out. Every 5 minutes even when i was driving!!
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto :oops:
1996 Fiesta 1.3 #-o
x 8325
chinkostu wrote:Mine went nuts until i figured it out. Every 5 minutes even when i was driving!!
Been there :twisted: Annoying isn't it.....
Mike, if my memory was okay I'd tell you how to re synch the plip :oops: My excuse is that I'm rather poorly and sending this from my tablet whilst lying in bed :( :evil:
x 8325
superloopy wrote:
Trust you're not too poorly Jim [emoji6]
No, not too bad Mike, my old problem has flared up a bit and I'm slowly rebooting. Hopefully back to normal in a day or so.
Looking at the forum is actually a bit of therapy :-D
x 8325
And thank goodness for tablets (of the Android variety) :-D Great for keeping an eye on the forum from one's bed....
chinkostu
x 30
You need a key as well as the fob to resync them. Some bizzare ritual of ignition and keyfob presses
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto :oops:
1996 Fiesta 1.3 #-o
MikeT
x 232
Unread post by MikeT »
CitroJim wrote:Mike, the alarm can be reset by holding down the ultrasonic disable (crossed - out speaker) button whilst turning on the ignition... :
Don't know if this applies to all xantia's but my alarm is cancelled just by insering key and turning on ignition - no need to hold the U/S sensor button.
chinkostu
x 30
Must be an X2 feature, mine will go off regardless!
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto :oops:
1996 Fiesta 1.3 #-o
wurlycorner
x 271
Unread post by wurlycorner »
You can also turn the alarm off by opening the bonnet and turning the key switch in the skuttle panel. It's on the passenger side IIRC, has a plastic flap covering over the top of it.
Hang on...
Here;
Excuse the quality of the pics, it's dark out there now :lol:
That 'permanently' switches it off (until you turn the key switch back on again). Remote locking/deadlocking from the plip still works fine.
I'd recommend silicone spray for freeing up the locks. They're a pig on my Activa too (what comes from sitting around for years :evil: ) Most important thing if there's a chance the battery will go flat before you next want to unlock the car... Don't deadlock it! (Not that I've found that out the hard way, you understand...)
Iain
CX DTR T2 Safari (silver)
chinkostu
x 30
That switch does sweet FA in my xantia btw. The old fellow before had removed the relay for the lights and said he'd disabled the alarm, if i remove the battery it will sound but if i alarm the car and open it/set off the ultrasonics it will only flash the lights, regardless of what I do with the keyhole!!
I got it working perfectly for about a week though!
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto :oops:
1996 Fiesta 1.3 #-o
x 8325
The key switch was deleted in later S1 models. My Activa lacks it..
Shame really as it was an excellent idea.
chinkostu
x 30
Do you have to turn it with the alarm set or unset? As my alarm now sets but doesn't sound!!
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto :oops:
1996 Fiesta 1.3 #-o
x 8325
I believe, may well be wrong, the switch only disables the siren, not the alarm itself....
chinkostu
x 30
it does, however my siren only sounds if you take the battery off! so i've got an issue somewhere
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto :oops:
1996 Fiesta 1.3 #-o
