2009 C5 handbrake error message
osx
(Donor 2022)
x 15
Re: 2009 C5 handbrake error message
Unread post by osx »
Only when I find my spare key. Not risking anything with one key !
C5 X7 Exclusive 2.0 HDi Auto
x 1999
Unread post by Stickyfinger »
then get someone to sit inside very still for a few mins just in case :)
osx
(Donor 2022)
x 15
Not getting any more handbrake/ABS errors and after 2 days of driving and having cleared all the faults I did another diagnostic. Only 2 faults this time.
SUSPVAR : electronically managed suspension
State of the ECU: SUSPENSION_ECOTECH
Faults present : 1
U2005 : triggering (vehicle speed receipt anomaly)
Characterisation : Not characterised
Status : Permanent fault
DSG : under inflation detection
Response data
State of the ECU: DSG
Faults present : 1
U1213 : fault in the vehicle speed information received by the CAN from the ABS or ESP ECU
Characterisation : incorrect value received
osx
(Donor 2022)
x 15
@RichardW
Any ideas? I think the second one may disappear if I retest shorty after driving for a while, but the first one?
Xantippa
x 29
Unread post by Xantippa »
You didn´t change the fusebox yet?
osx
(Donor 2022)
x 15
No as I am not getting any ABS/ESP hand brake alerts any more.
x 1485
It's the same thing though... I'd change the FB next. If you know someone with a similar car you could swap it out to see if the fault goes away. If that doesn't fix it, then likely you are looking for a dodgy wire - good luck with that!!
osx
(Donor 2022)
x 15
Is it an easy swap? Too many FB's - need to swap the right one!
x 1485
It's easy as far as I know - although I have so far failed to get to it on our C4.... :? It's the top one under the cover at the rear NS of the engine bay. Take the battery off, taking the usual precautions; remove the cover over the fuses; unclip the connectors on the top (4 I think); undo the nut on the main power feed and lift the wire off; release the two clips at either side and lift it out. Refit reverse of removal. AFAIK there is no need to configure the new one once fitted - just check the two side by side, and that all the fuses required on the new one are fitted.
Xantippa
x 29
On mine it was 9675877980. And part is dirt cheap (about 50€), at least in http://www.citroen-accessories.com" onclick="window.open(this.href);return false; it was about two months ago.
osx
(Donor 2022)
x 15
Not very expensive but would like to try a swap first to make sure it's not a cable.
osx
(Donor 2022)
x 15
RichardW wrote:It's easy as far as I know - although I have so far failed to get to it on our C4.... :? It's the top one under the cover at the rear NS of the engine bay. Take the battery off, taking the usual precautions; remove the cover over the fuses; unclip the connectors on the top (4 I think); undo the nut on the main power feed and lift the wire off; release the two clips at either side and lift it out. Refit reverse of removal. AFAIK there is no need to configure the new one once fitted - just check the two side by side, and that all the fuses required on the new one are fitted.
Do you think it could be a blown fuse? I will check them tomorrow if they are not many.
x 1485
Unlikely.... there are about 20 on the underbonnet fuse box!
osx
(Donor 2022)
x 15
Nothing wrong with the fuses and the fuse box is the newer one so it seems it has been replaced (although date is Sep 2008)
osx
(Donor 2022)
x 15
The only thing I didn't check were the connectors and I've been told that they are susceptible to water corrosion! If there is any evidence of water corrosion, a new fuse box it is. Still under warranty until June so need to have it sorted by then.
