FakeConcern's XM
Fake Concern
- x 65
Re: FakeConcern's XM
Now to ask for some forum help!
The one thing that doesn't work & is really annoying is the remote on the central locking. It all locks & unlocks from the key fine. The key remote LED comes on. I tried changing the batteries, I tried syncing (ignition on, press button for one second, found on XM forum, is this right?). Where do I go from here?
- x 1452
I have not needed to do anything to mine other than change the batteries. But you should know that the RF plips used on the mk2 XM are not like anything used on any other Citroen. They are a rolling code remote, so send a different code every time the button is pressed, and the receiver ignores any duplicate codes received, to prevent replay attacks.
Neither the plips nor the receiver can be programmed to add new plips to a car. At one time, it was possible to order a specifically programmed plip from Citroen, at a typically customised price. Now the only options are to get a matched pit of plips and receiver from a scrapped car, or fit an aftermarket remote system.
It is possible that the plips you have (or at least the internals) has been swapped and does not match your car. It would be worth asking the previous owner if it was working.
It might be worth trying the standard trick of resoldering all the connections on the PCB, which has fixed more than one Xantia plips for me.
Fake Concern
- x 65
Thanks for the reply, do you mean solder the pcb in the remote key?
Is the receiver in the interior lamp housing?
- x 1452
Yes I meant resolder the plips PCB.
The receiver is mounted under the glovebox.
Fake Concern
- x 65
Got home from work today to find two XM things in the post, the reg doc, so I'm officially the keeper & the Haynes BOL for the XM. Unfortunately the BOL does not seem to include the V6, a bit annoying! I want to change the oil/filter ATF over the Easter holidays, I've had a search around the forum & can't find a guide to either, is there one?
- x 8368
No, but Club-XM.co.uk will advise all you need to know Fake...Fake Concern wrote:I've had a search around the forum & can't find a guide to either, is there one?
Fake Concern
- x 65
OK trying there now!CitroJim wrote:No, but Club-XM.co.uk will advise all you need to know Fake...Fake Concern wrote:I've had a search around the forum & can't find a guide to either, is there one?
Fake Concern
- x 65
XM found a friend!
- x 5671
Mr Dollywobbler of this parish, if I am not mistaken.
Fake Concern
- x 65
I thought he lived in Walesmyglaren wrote:Mr Dollywobbler of this parish, if I am not mistaken.
DHallworth
- x 167
I knew I'd seen this picture somewhere else!!
The owner of the 2CV posted it on Facebook earlier!!
David.
David.
'98 Xantia Activa V6
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
- x 5671
It is up on autoshite now tooDHallworth wrote:I knew I'd seen this picture somewhere else!!
David.
- x 5671
Fake Concern wrote:I thought he lived in Walesmyglaren wrote:Mr Dollywobbler of this parish, if I am not mistaken.
He gets around
Fake Concern
- x 65
It's famous!myglaren wrote:It is up on autoshite now tooDHallworth wrote:I knew I'd seen this picture somewhere else!!
David.
He certainly does!myglaren wrote:Fake Concern wrote:I thought he lived in Walesmyglaren wrote:Mr Dollywobbler of this parish, if I am not mistaken.
He gets around
daviemck2006
- x 496
It's sure going to be a famous xm. A beautiful one too. I think i really need to sample one.
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
Peugeot boxer 2016
In the family
