Anti-Roll Bar Bushes C5...09
x 1996
Unread post by Stickyfinger »
OK, a question.
I have to do the rear anti roll bar bushes on my c5 tourer as the warranty does not cover it. The powder coating is breaking up destroying the bushes. (in argument with Citroen as this started at least a year ago and the car has "full service history" main dealer Abingdon, Hartwells. I regard this as long term neglect by them , Hartwells as the problem must of been there for many miles.
So I checked the price of parts just in case I need to do it myself.....
Citroen parts have just told me you cannot get bushes, just the roll bar AND the bushes for £351 plus the dreaded.......do you know better ?
x 94
Re: Anti-Roll Bar Bushes C5...09
Unread post by citronut »
lets have the last 8 digits of your chassis/VIN No. and i will double checxk what your dealer is telling you
Regards, malcolm.
osx
(Donor 2022)
x 15
Unread post by osx »
Ouch. Why are they so expensive? Never heard of a car being re-powdered as part of the service though
C5 X7 Exclusive 2.0 HDi Auto
x 1996
Not that, the fact the coating must of broken down a long time ago when it WAS covered, they just did not say anything at the time because the breakdown in the component coating had not caused to much damage yet....hence my position of "supervised neglect" regarding the service at Hartwell in Abingdon. It is a Citroen Dealer issue not the warranty in my way of thinking.
( The basic point being Powder Coating is NOT a suitable coating to apply bushes on top off, it is not a mechanical surface and this WILL effect every car so fitted)
x 94
here you go Mr Fingers
REAR ANTI-ROLL BAR
DIAM 21
i recon the price you quoted above was including fitting
00005170G1 R/ANTI-ROLL BAR 167.93 GBP 201.52 GBP 201.52 GBP
and yes the bushes do only show as with the roll bar,
just in case i havent already sent you your cars birth certificate i have pm.'ed it
Regards, malcolm.
x 1996
Thanks mate.....that is so strange. So now I may have to wok out why only with a roll bar and then find a replacement bush....200 notes for 20 notes of rubber....frack that !
Lenny
x 62
Unread post by Lenny »
http://www.nagara.co.uk/MakingBushes.htm" onclick="window.open(this.href);return false;
Make your own poly bushes?
x 1996
LOL
Anybody got an Image of one off the car ?
x 94
i just did a goooogly search for citroen 21mm anti roll bar bushes
https://www.google.co.uk/?gws_rd=ssl#tb ... bar+bushes" onclick="window.open(this.href);return false;
so then looked back at service citroen under C2
5094 A5
ANTI ROLL BAR BEARING
DIAM 21
they dont look like a D bush, not sure if they are any good
did another search but deleted the word citroen
https://www.google.co.uk/?gws_rd=ssl#tb ... 1569097894" onclick="window.open(this.href);return false;
Regards, malcolm.
x 1996
http://www.ebay.co.uk/itm/1x-Febi-Rear- ... 51c68a1c50" onclick="window.open(this.href);return false;
For the cross-over.....I think maybe 19.5mm without the nasty powder coating applied over it.
BUT
Why only WITH the bar....it makes zero sense to do this....
osx
(Donor 2022)
x 15
Doesn't seem to fit your C5 if their compatibility list is up to date.
On another note I got my brake abs fault light twice yesterday ;-) so it seems I will be heading your way
x 1996
osx wrote:Doesn't seem to fit your C5 if their compatibility list is up to date.
That's the point mate, nothing is listed as Citroen decides the Roll Bar comes free with the replacement bushes for £200 instead of £30 for rubber, nice of them.
I am thinking 19.5mm to take up the missing powder coating but I need to get the shape correct.
handbrake@ maybe later then :)
x 1996
dats the little @@@@@@r.......will get a close up tomorrow, but to me that looks quite standard...whut u rec ?
ps...not my car
osx
(Donor 2022)
x 15
The one at the top left? Doesn't look very special. Are the drop link ones ok? They seem to be the same colour ;-)
x 1996
Yep that's the one....(it is not my car in the photo).....my bushes are getting damaged by the black plastic coating on the roll bar and thus is now in sharp bits under the bush....nice
As you say, it does not look that special, we shall see tomorrow when I get under my car.
drop links are fine
