st st stuttering 2004 c5 hdi
zs&tas
x 16
Unread post by zs&tas »
Hello ! Thought id start this up for help, a chat and it maybe of use to others.
So far the car has started to stutter, seemed to be under hard acceleration but now inconsistently in any condition , it will go with out a problem then do it again. It feels like the brakes are momentarily on, then in an instant off again. Its had a tank of fuel with cleaner and an italian tune up, but its still bad.
Seems a lack of power (its the 138)
I cant access my friends computer so a mans coming tmrw to do it. His first thought on the phone was the diesel filter ?
Lets see what the computer checks out.......
x 1996
Re: st st stuttering 2004 c5 hdi
Unread post by Stickyfinger »
agree,
Fuel filter first look
hamster99
Unread post by hamster99 »
I'm having a similar issue with mine.
It's very intermittent and often unrelated to driving style, speed etc. Most advice is the diesel fuel filter so will be changing mine this weekend.
22 C4 1.6 eHDI Shine Plus
67 RR Autobiography 4.4 SDV8
15 C4 1.6 eHDI 115 Exclusive - fond memories
12 RR Westminster 4.4 TDV8 - Gentleman's Club on wheels
05 C5 2.0 HDI 138 Exclusive - gone but not forgotten
05 C5 2.0 HDI 138 VTR - crushed May 2015
zs&tas
x 16
Gd to hear I guess, would have thought it would have caused more consistent problems though. I think my filter is 10k and one year on it.
x 1996
they be guess work ....it may be other problems such as electrical.
What car, engine age etc will help as well
x 1240
Unread post by Peter.N. »
If its the filter it will usually fail at times of high fuel demand or going up hill.
hamster99
Yeah did that alarmingly the other day when I tried to overtake a truck... :yikes: :yikes:
Never changed it before and I've done 75k in it so probably a smidgen overdue :rofl2:
x 1488
75k would almost certainly do it - there's no LP pump on these so it has to suck through the filter.
x 1996
or just one crap batch of fuel as well ....ask me how I know ?....three filters later before I worked it out and took the tank out
hamster99
Well, just replaced the fuel filter, not that difficult.
Now it won't start.....!!!!!
Everything's reconnected and initially it started but then immediately cut out. Now it won't start at all. Cranks ok but seems like it's not getting fuel.
Any suggestions, I need the car for work in the morning so getting a bit desperate.....
Rob
x 1996
Have you a primer bulb on top of the engine ?
got an air leak ? does the tank pump (if you have) run ?
hamster99
yes, i primed it until the bulb went hard
now if i do it and leave it a few minutes the bulb is soft again!
it just started then cut out straight away and wont start again
cant think whats happened, all seemed so easy
is it possible the HP pump is not working? is there a fuse?
x 1996
do you hear a LP pump in the tank running when you turn on the ignition ?
This is a good procedure to follow generally..http://www.frenchcarforum.co.uk/forum/v ... c5#p430605
edit....going out soon.....someone else jump in please
hamster99
UPDATE:
Just checked all connectors (again), primed with the bulb, and it started after a couple of seconds......!!
This time I floored the accelerator when it started and it stuttered but carried on running at about 2000rpm for a few minutes.
Then left it idle for about ten minutes and now it starts fine again......
Weird.....
Thanks for the advice, appreciate i was panicking a bit.....
x 1996
Good job.....panic over....air lock :)
