c8 died with battery light while driving
pde
New User
Unread post by pde »
Hi all,
I experienced what I thought was a strange failure with my 2006 c8 2.0 petrol last night. While doing nice and even 90 km/h the battery light came on, flickered off for a second, then came on again and the car got noticeably weaker.
I immediately suspected the alternator and "limp mode", but assumed I would be able to run on battery for a while to be able to get off at the next filling station.
Alas, the ride lasted no more than 30 seconds from the initial battery light and I was barely able to roll off the main road with a dead engine.
Subsequent start attempts were unsuccessful - starter pulled strong but no ignition. I also tried to reset the car by disconnecting the battery minus for 10 min but to no avail. No other warning lights or messages from the car, but it eventually entered "economy mode".
The car finally got towed and I'm waiting to hear back from the shop. Curiosity finally got the better of me though so I had to post here to see if there is someone with more experience than myself that can tell if this is consistent with a broken alternator or if there is a better explanation.
Cheers
2006 c8 2.0 petrol
spider
x 77
Re: c8 died with battery light while driving
Unread post by spider »
Did you lose any other electrics ?
This sort of sounds a bit like a main engine earth lead has gone as that can have very very strange effects if it happens while you're moving, I've had one break years ago, instant loss of lights and everything else. Engine kept running but battery light remained on.
At least its easy to check them I guess, I'd examine the earth lead on the transmission as a starting point.
Andy.
pde
New User
Thanks for the theory! All other electrics working just fine as far as I could tell. Pulling nicely on the starter but wouldn't run and not a hint of ignition.
Cheers
2006 c8 2.0 petrol
x 2007
Unread post by Stickyfinger »
Times like this you can guess endlessly.....you need it on a lexia mate
