New spare key
osx
(Donor 2022)
x 15
New spare key
Unread post by osx »
How much does it cost to get a new spare key? Doesn't need to have remote, just something that can be used as a backup. It will be for the new family C5 X7.
C5 X7 Exclusive 2.0 HDi Auto
vborovic
Locked user account
x 40
Re: New spare key
Unread post by vborovic »
Example: http://www.ebay.co.uk/itm/Citroen-C1-C2 ... 23495d8c37" onclick="window.open(this.href);return false; ... I think it shouldn't cost much more than that
osx
(Donor 2022)
x 15
Re: New spare key
This item does not fit Citroën C5 2008 RD_ [2008-2014] Saloon 2.0 HDI.
vborovic
Locked user account
x 40
Re: New spare key
They didn't bother defining all the cars in the compatibility list except the Berlingo. The ad states (quote):
We do all keys including lost keys
C1
C2
C3
C4
C5
C6
C8
Dispatch
and others
x 1489
Re: New spare key
If you don't want a remote, a new key can be had for about £10. Get one that is ready cut though - I found that the high street chains were reluctant to key aftermarket keys they didn't supply. You need the 4 digit confidential code that came with the car, and a Lexia to code it. Don't buy a second hand key - they can't be re-coded to a new car (whatever the sellers try and tell you!).
osx
(Donor 2022)
x 15
Re: New spare key
vborovic wrote:They didn't bother defining all the cars in the compatibility list except the Berlingo. The ad states (quote):
C1
C2
C3
C4
C5
C6
C8
Dispatch
and others
There are plenty of different C5's. It states clear when you enter the exact model that it will NOT work the C5 X7
vborovic
Locked user account
x 40
Re: New spare key
Maybe we're not seeing the same data if logged in to eBay (you're from UK, I'm from outside of UK) ... when I click the "show all compatible vehicles", I only get 5 pages of Berlingos, ranging 2008-2014, all engines ...
osx
(Donor 2022)
x 15
Re: New spare key
Same page but I entered the model at the drop down list. When you do this for the Berlingo you get the same message about not fitting Berlingo ;00
x 1489
Re: New spare key
£21.50 from here
osx
(Donor 2022)
x 15
Re: New spare key
Thanks Richard.
So what I have to do is buy the one with transponder and cut (not sure why there is an uncut option) and then find someone who has a Lexia and knows how to programme it?
x 1489
Re: New spare key
That's about right - you could get it cut yourself, but the cost works out about the same. It's easy to programme the keys with Lexia - once you find where it's hiding :roll:
x 1996
Re: New spare key
Unread post by Stickyfinger »
RichardW wrote:That's about right - you could get it cut yourself, but the cost works out about the same. It's easy to programme the keys with Lexia - once you find where it's hiding :roll:
FYI, I have never done that on a Lexia.....so be warned if you do make it down.
osx
(Donor 2022)
x 15
Re: New spare key
Had read about it a while ago but if there is any risk of bricking the ECU I might leave it for later.
x 1996
Re: New spare key
osx wrote:Had read about it a while ago but if there is any risk of bricking the ECU I might leave it for later.
Do not think that is likely, however there is a specific procedure to ensure the details of the keys are matched....would be good to have that printed to tick off.
vborovic
Locked user account
x 40
Re: New spare key
I'm looking through the Service Documentation, there is an entire theory behind the coded key ignition sequence available, but so far can't find the actual coding of a new key to the transponder ...
